I have a 95 855 turbo that ive almost got back roadworthy (thx to the help here!)
One question i have os re: the turbos.
My complete parts car is a 1997 855 turbo
What turbo does my parts car have ?
16T?
And my 95 has a 13G?
Is this correct?
I should swap turbos right? 16T is better right?
1997 vs 1995 turbos
- echosierra
- Year and Model: 1995 855T
- Has thanked: 1 time
1995 855 Turbo
- Has thanked: 311 times
- Been thanked: 817 times
95 turbo cars were all HPT (high pressure turbo) engines, with a 15g.
In 97 there were two NA market 850 turbo cars
- HPT with a 15g, this was the R and the T5 trim models
- LPT (low pressure turbo) with a 13g, this was the GLT trim model
If you want to be really sure what turbo it is, just look at the name plate on the turbo. You can do this while they are in the car. It will say 13g, 15b, etc. see viewtopic.php?f=1&t=91466&p=521707&hili ... 3g#p521707
Smaller turbo means less boost yes, so the 13g provides less boost than the 15g, etc. The 16t first came on HPT cars, the T5 and the R.
There are other factors to consider than just the size of the turbo when putting together the power plant. For example, there is generally no point in switching the turbo unless you also switch the injectors and the ECU.
