Easy Valve Ticking Question (for some)
greg850r
Year and Model: a long list
Been thanked: 11 times
Re: Easy Valve Ticking Question (for some)
Post by greg850r »
I experience the same lifter tick you describe in many of mine when they sit too long. Cure is to drive it more, or if you instantly want it gone, a pint of marvel Mystery oil in the crankcase will immediately cure it.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 181 times
Post by bmdubya1198 »
June wrote: Sat Nov 02, 2019 9:10 am Actually the dealer told me years ago 5,000 rpm for 5 minutes under load ac off. That was for the 1998 V70 5cyl turbo that had problems with valves sticking causing hard starts and engine vibration. It would then be fine for 6 months. I have done just that with every Volvo since about every 6 months after a fresh oil change. So my current 2004 S80 T6 has undergone this process without issue. In fact the S80 T6 is so smooth and quiet it is almost not noticable that the engine is turning 5,000 rpm.
The 960/S90 manual had a section stating if the engine ticks when starting cold, it may require up to 20 minutes to subside. Do not exceed 2,000 rpm until quiet to prevent engine damage. If it exceeds 20 minutes tow in for service. I don't recall seeing that information in the T6 owner's manual. June
Good advice, definitely the way to do it if you don't drive at high RPM regularly.
I also remember this from my S90's manual, it had a section explaining that it was normal due to the HLAs, which were new for the white blocks. Red blocks used solid lifters.
WhatAmIDoing wrote: Sat Nov 02, 2019 1:34 pm My 98 S70 T5 has had that ticking noise for at least the last 9 years (according to PO + tie I've owned it). Had a chat with Robert about it. He said unless your car takes more than a second to build oil pressure or you have the low oil pressure light coming on, just ignore it and give it the old Italian tune up once in a while. He said same goes for the oil sump O-rings. Unless you are getting a low oil pressure warning, not worth doing.
I've tried oil grades from 0w40 to 5w30 to 10w40. Nothing quiets down that ticking. HM oils are okay if you stick to reputable brands like Mobil or Castrol. Do NOT go out and put Supertech HM in your engine.
The issues my cousin's car had were with Mobil 1. I definitely wouldn't use Supertech though!
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 57 times
Post by WhatAmIDoing »
bmdubya1198 wrote: Sat Nov 02, 2019 5:30 pm
I ran it on Rotella T6 5w40 for 7500 miles and noticed no change. Last oil change was M1 because I had 7 liters on hand. Might try Castrol next. Also poured in half a bottle of Marvel and noticed no change. Might try MoS2 next.
I got to show off my car to Robert, and he said it may not even be the lifters making the noise. Unless you have a low oil pressure light, don't worry about it. So I guess I can stop worrying.
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
Knows enough to be dangerous :wink:
bmdubya1198
I've been happy with Castrol, that's what I'm running now. I go back and forth between M1 and Castrol 0w40 in my R. Same with the XC90 and S60.
'99 BMW 528i
'01 Mountaineer 5.0
