S60 ABS module
ronjag
Year and Model: 2004 s60
S60 ABS module
Post by ronjag »
Hi, im looking for an abs module, part number is 8671457, it is for the STC system.
Willing to travel or pay postage.
Thanks
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Are you sure this part number is correct? can you take a photo of module please?
ronjag
Post by ronjag »
Hi, i took the car to a volvo specialist, he told me that was the part number i needed, it seems as though the previous owner swapped the module and fitted the wrong one, im getting anti skid service and cannot delete because its the wrong module.
cheers
ronjag
Post by ronjag »
Hi, the part that is on the car is the wrong one so wouldnt be any point in taking a photo.
I believe the one i need has only 8 pots in the module and not 12 which it currently has.
Thanks for reply
yagger
Post by yagger »
For S60 2004 MY you need BCM 8671224
ronjag
Post by ronjag »
Hi, thans for reply, that is the one that is on the car when i bought it, i sent it off to ECUTESTING in derby, they tested it and said it was fine, but as previously posted, i was told by volvo specialist in burntwood that the wrong one was fitted, isnt the 1224 dstc? Where as my car only has stc, bring back cars with no modern electronics, the abs light is NOT on and the brakes work fine, its just that nobody seems to be able to cancel the anti skid service message
Thank for taking the time to reply
Ron
yagger
Post by yagger »
STC or DSTC configuration programmed to module.
If you have anti skid service message on the display you have to get errors codes first.
ronjag
Post by ronjag »
Hi, when it was first plugged into a diagnostic it showed codes of 0130 and 0131, now it is showing 0139
Pressure build up valve power brake booster signal outside its permitted range
DTC Status
Present.
Thanks for your suggestions.
KennethMcNutt
Year and Model: 2004 S60
Post by KennethMcNutt »
Hoping you can help.. I replaced my BCM with one from a 2003 XC90.. Not knowing much about Volvo I did at least confirm that that year's make and model did come with the same unit.. But what I didn't know was since it was AWD and dstc it couldn't be just reconfigured ?? I has taken me down a rather steep learning curve road!! The car had a few issues the CEM being one of them also... But I believe I have enough of an understanding of Volvo to say rather surly that what I have on the car currently will work as long as can find someone with the software to reload my BCM That's how I came across you @yagger There is talk you can do it remotely?? I have Vida and Dice and enough know how it flash it myself yet I can't find ANY flash file except the ECU... Not really understanding why that is :( But Can you please help me Sir??
Has thanked: 1506 times
Been thanked: 3819 times
Yagger has a link to his services in his .sig, email and phone are there!
Good luck!
