05' V70, almost dead battery, alarm going off, what to do? Topic is solved
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Yesterday evening I went to the carport to move the my V70 into the driveway. The forecast called for strong winds and ever since an oak tree crushed the old carport in a horrific storm last year, I feel uneasy leaving the car in there during these times.
Well I was stumped when I approached the car because the doors would not unlock with the remote. I then proceeded with opening the drivers door with the key, and when I pushed the unlock button inside the car, the alarm goes off. Great. Interior lights came on, but were very dim.
So I go back to the house to get some tools and luckily at some point the alarm stopped. Then I unlocked the rear doors manually and made my way to the battery from the inside since the tailgate won't open.
That was a fun acrobatic exercise :o
The battery is now charging and I'm planning to put that back in on the weekend.
But here is my question: Is there anything I need to pay attention to? Or is there a special procedure?
If at all possible I want to avoid the thing freaking out at me again because I did something wrong.
Thanks for all your ideas,
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Make sure you follow the battery disconnect/reconnect procedure.
https://howardsvolvos.webs.com/miscissues.htm#207347288
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Just keep it better charged and it'll be fine.
Having the key in position 2 is for your own safety. If the airbag blows when power is restored you're not behind the wheel and can't get hurt.
Has thanked: 1611 times
Been thanked: 4073 times
If it is more than 3 years old, go get your self a new one with all the money you saved on the 1999 Nautic Blue/beige NA wagon in stick shift, you rascal.
P2s really hate low battery voltage, and if it has discharged in a week of non-use, its dead. It will keep you in Volvo electronic Hades until you get a new one.
850 LPT
Post by 850 LPT »
93SCMax wrote: 01 Nov 2019, 09:55 Make sure you follow the battery disconnect/reconnect procedure.
Interesting to read this, thanks. I am guessing I will be fine as far as the ECC is concerned, since I haven't driven the car in 2+ weeks.
850 LPT
Post by 850 LPT »
abscate wrote: 01 Nov 2019, 10:35 If it is more than 3 years old, go get your self a new one with all the money you saved on the 1999 Nautic Blue/beige NA wagon in stick shift, you rascal.
Using "Volvo" and "saving money" in one sentence does not go together :shock: Also, the nautic is a fine S70 sitting in the garage waiting for attention. This one has the benefit of being connected to a maintenance charger unlike the V70.
Just checked and the battery in the 05' V70 is a little over 3 years old. Surprising it doesn't hold a charge better.
Put it on a good 10A charger for a few days and see what state it is after that. Ive got a couple of good spares if you want to test, too. Im driving by 87 almost weekly now with a NJ client this year.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If the battery was flat, unlocking the door with the key has set the alarm. The alarm system will detect if one door is opened while the car battery is disconnected or flat, and will trigger the siren.
For how long was the car parked ? If you happen to park it for longer periods (2-3 weeks or more), it's a good idea to leave it with the battery disconnected, because when it goes flat it can cause an annoying immobilizer problem. To do so, open the hood, lock all doors but the driver's one using the remote fob, disconnect the + cable under the hood (not inside the trunk because as you found out you have no access in the V70), close the hood and finally lock the drivers door by turning the key inside the barrel - this way the alarm will not sound (the downside is the alarm will not be engaged)
850 LPT
Post by 850 LPT »
This is great info Oragex, thank you so much!
The car was indeed parked for about 2 1/2 weeks. And I didn't drive any kind of long distance prior to that, which is probably the reason why this happened.
From now on I will drive it to work every once in a while (85 miles per day) to prevent this from happening again. Lesson learned.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
850 LPT wrote: 01 Nov 2019, 13:17 This is great info Oragex, thank you so much!
Install a float charger and plug it in. Float chargers cost $7.00 +, a whole lot less then a new battery.
Active
Past
