Correct torque for head bolts?
Jibbaman150
Year and Model: 2005 xc70
Has thanked: 1 time
Post by Jibbaman150 »
I have definitely researched this topic. Most of what read is 15 ft lbs first pass 44 ft lbs second pass then 130 degrees, on my 2005 xc70. Problem is that the machine shop I took my head to printed me out all my engine specs from AERA engine builders association. On the print out it says 15 ft lbs, 30 ft lbs, then 130 degrees. (30 not 44) so just looking to get some clarification from someone who’s done this before. Thank yal!
gcha8e
Year and Model: 2005 S60 2.5T AWD
Has thanked: 20 times
Been thanked: 2 times
Post by gcha8e »
Go up to 30, then the 130 degrees, if it feels right, keep it, or if not, give it another 45 degrees turn. You'll be fine. (no I have not done it before) :D
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Per Volvo Vida:
Tighten the screws in sequence from the center and outwards.
Stage 1........20 Nm (15 Ft-lbs)
Stage 2........60 Nm (44 Ft-lbs)
Stage 3........130°
Active
Past
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
I always use 44ft-lbs for the last torque before putting the dial on it.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
Jibbaman150
Has thanked: 1 time
Thanks guys, thanks Rick for the Vida reference.
Hey does anyone know what the cross-hatching is supposed to look like on the cylinder walls? Mine are at about a 60 degree angle and almost look like scratches. I have some pictures just got to figure out how to upload them.
RickHaleParker
Jibbaman150 wrote: 03 Nov 2019, 09:24 I have some pictures just got to figure out how to upload them.
1. [Full Editor & Preview] Scroll down it is below the default editor.
2. Scroll down [Attachments]
3. [Add Files] select the pictures.
4. [Place inline]
5. [Preview]
6. Make formatting adjustments as needed.
7. [Submit]
Active
Past
Has thanked: 1610 times
Been thanked: 4068 times
Typical error on torque wrenches is 25%, so don’t get too hung up trying to get these settings “ exact”
Try to be consistent, rather than exact. On the head, torque even-ness is more important than actual value,within reason. New bolts too, please.
Jibbaman150
Has thanked: 1 time
Consistently is key, got it!
Ok here are my cylinder walls, only 100k miles on the car so I’m really hoping these aren’t scratches..
Francisco1999
Year and Model: 2016 v40 2.0t
Post by Francisco1999 »
Hola
Yo necesito el apreté de la culata del v40 2016 2.0t B4204T19
Francisco1999
Hola
