A handbrake story Topic is solved
gcha8e
Year and Model: 2005 S60 2.5T AWD
Has thanked: 20 times
Been thanked: 2 times
Post by gcha8e »
Sheared off the the threaded end of the e-brake cable
:evil:
The story.
Upon totaling my second car in two years I stumbled upon this Volvo. I liked that it had anti-lock brakes, supreme comfort, and the turbo with AWD. (better brakes could have averted my second incident).
I did not notice however, that the handbrake did not operate. Right after buying it from the previous owner, I then had to take it in to the shop twice for work, and ultimately replaced the pad and the shoe on the handbrake with genuine Volvo parts because the brake would not hold without the Volvo brake shoe. Cost - $500. :roll:
It's been a few years, now I noticed that the handbrake doesn't hold the car on a hill facing downhill. It only holds going uphill. So I decided I'll adjust it because it takes more than 5 clicks to apply the brake .
The result was that after about a revolution and a half on the nut, the end of the cable snapped off. Don't let this happen to you. I now have to redo the cable end or get a new cable and STILL have to figure out the uphill problem. :x
It didn't take much, the cable was already adjusted to max - apparently. :(
RichCrewe
Year and Model: S60 2002
Post by RichCrewe »
I had a bad e-brake/hand-brake for about 10-years, replacing the pads didn't help and I went through about 4 sets over that 10-year period, I'd got used to it and had it down as a quirk of the model. I was replacing the shoes again that I noticed that one of the cables running to the rear was seized, I replaced both of them, after that it actually held on a decent hill. Only one side had been doing anything and the effect of the seized cable on the yoke was that of halving the force to that working side, so 25% of the designed brake efficiency.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Find a threaded sleeve like the one in the HD picture below or the use the long nut on the bolt in your picture and Loctite the two section back together.
https://www.homedepot.com/p/Arnold-Univ ... /300614281
MoVolvos
Post by MoVolvos »
Not sure which part it is as there seems to be several sections. Assuming it is #9 it's not available as far this dealer is concerned.
https://www.volvopartswebstore.com/show ... evel=24650
gcha8e
Post by gcha8e »
@ Rich Crewe I'll have to take a closer look at the rear cables, that's a very good possibility that something is seized up. Thanks.
@ MoVolvos, yes, it's #9 the equalizer bracket and cable. Buying and end piece like you showed seems like a good plan, but it seems like the cable is crimped into the bolt part somehow, and I don't think I'd have the tools for it.... I guess that's another tool to buy?!
As to Loctite, are you referring to super glue? I don't see how that will hold up, it will just break right off. I have some JB Weld as well and I'm sure that would not hold it. It's simple, and I'd try it to just try it, but not going to hold my breath. :P
gcha8e
Post by gcha8e »
FCP out of stock but googled the part and it's $20
https://www.ipdusa.com/products/9605/12 ... 84-9191484
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I think MoVolvos means a coupling nut - a long nut that is fully threaded and can be used to connect the broken ends together. This assumes you have at least some of the threads remaining on both parts. The Loctite he is suggesting is Loctite thread locking compound. It will be applied to the threads when the ends are screwed on the coupler nut. The thread locker will prevent the threads from loosening over time.
Volvolugnut
MoVolvos
Post by MoVolvos »
volvolugnut wrote: 03 Nov 2019, 17:39 I think MoVolvos means a coupling nut - a long nut that is fully threaded and can be used to connect the broken ends together. This assumes you have at least some of the threads remaining on both parts. The Loctite he is suggesting is Loctite thread locking compound. It will be applied to the threads when the ends are screwed on the coupler nut. The thread locker will prevent the threads from loosening over time.
Volvolugnut
Thanks, that's what I said. Not sure how or if a coupling will fit in the overall system / brackets but that is just one way to reconnect the broken threaded ends. There are smooth coupling and one that looks like a nut so some research will be needed.
MoVolvos
Post by MoVolvos »
gcha8e wrote: 03 Nov 2019, 13:42 FCP out of stock but googled the part and it's $20
From the Volvo diagrams one can't tell what it looks like. Thanks.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Another thing to consider on these is the "expander" or "dolphin", as this lady calls it, often becomes rusted & basically immobile. The hinge point is essentially just a zinc'd rivet that corrosion affects over time, eventually limiting it's range of motion to nil. They are salvageable, don't cost much new but why buy a new pair if you can rejuvenate the old ones? Takes some media blasting, beating in a vise & some greasing & fiddling around but end result is nice if done right. Then your only cost is a spring set, shoes, and a new lead cable if yours is busted. I haven't seen seized cables in the sheaths ever, it's always been the expander in my experience.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
