IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
My Impact Wrench Is Not Strong Enough
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 23 times
Been thanked: 44 times
United States of America
MoVolvos
Re: My Impact Wrench Is Not Strong Enough
Post by MoVolvos » Sun Nov 03, 2019 6:36 pm
Oka wrote:
Sun Nov 03, 2019 2:23 pm
For such air tool, an eight-gallon tank would not be enough, would it?
Tank size only matters if you require continuous (?) CFM @ a certain psi. For a DIY a smaller tank can potentially work. Have to check the Airtools you intend to purchase. I would say a minimum of 2HP depending on the brand.
"Powerful 2.5 HP 4-pole motor produces 4.2 CFM at 90 psi for increased productivity"
https://www.homedepot.com/p/Makita-4-2- ... 00%7D%3Aqu
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 58 times
Been thanked: 6 times
GlennG2759
Post by GlennG2759 » Sun Nov 03, 2019 7:16 pm
I recently purchased a cordless 20V Porter Cable Impact gun. My primary use was going to be for rotating tires, the advertised max torque was way higher than it can actually deliver. I don't trust it to deliver the torque required for tightening wheels. How many FT/LBS. have you lost by the time you get to the 20th lug stud. I've basically shelved it and prefer using my cheapo 1/2 Lowes (kobalt) air gun and 20 gal. compressor, I can get 120 psi out it.
Oka
Year and Model: XC70, 2001
Has thanked: 0
Been thanked: 0
Oka
Post by Oka » Sun Nov 03, 2019 7:24 pm
vtl wrote:
Sun Nov 03, 2019 6:15 pm
I wrench by hand, too, where possible. However this tool is still handy when you need to undo nut on crankshaft or Haldex. That says, I barely use it :)
I also barely use it. But when switching to studded tires, I would have to switch at least eight tires. Too much to unlock the lug nuts by hand wrench before using the impact wrench for speed. If I could use the power too from start to finish, that will be a plus for me.
1985 BMW (E23) 735i(US)/AUTO/209K Miles
1997 Mazda MPV/AUTO/4WD/173K Miles
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles (Brown)
2001 Volvo XC70/AWD/Auto/Turbo/144kMiles (Burgundy)
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
MoVolvos
MoVolvos
Post by MoVolvos » Sun Nov 03, 2019 7:42 pm
20V Porter Cable Impact gun... I don't trust it to deliver the torque required for tightening wheels. How many FT/LBS. have you lost by the time you get to the 20th lug stud. I've basically shelved it and prefer using my cheapo 1/2 Lowes (kobalt) air gun and 20 gal. compressor, I can get 120 psi out it.
The 20 Gallon with 120 PSI delivery is the most ideal for anyone who likes to work on cars. Unfortunately, most DIY'er won't shell out for such a large unit besides space constraints in the garage. When you exceed a certain HP you'll also have use 220V 1PH meaning a new Breaker and Wiring.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
MoVolvos
Post by MoVolvos » Sun Nov 03, 2019 7:43 pm
Don't know about you but age becomes a factor.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 229 times
Been thanked: 759 times
Trinidad & Tobago
Post by abscate » Mon Nov 04, 2019 4:41 am
I don’t trust the impacts to give me the torque I like on lug nuts. I lube mine so I torque to about 75 Nm
I crack them with a 24 inch breaker ( easy) then use a cordless 125 ft lb Bosch 1/2 to zip off and zip on.
I then do a final nip with the 24 inch on all nuts to my final torque. Hard to describe but I’ve learned the correct tightness where they never loosen, but all of the ladies can loosen them with the car lug nut wrench. The smallest , Abby , uses her foot, while my soccer athlete can twist them off with her fingers. ( badly behaved boyfriends get their limbs pulled off before they get wood chipped)
Oka - there is a thread from the P80 Forum discussing these from two years back here
viewtopic.php?f=1&t=84000&hilit=impact+Bosch&start=10
The 125 ftlb Bosch my kids bought me is a champ for the zipping on and off. If you really want to not use the cheater, I think you will need a pretty expensive 3/4 inch, 12.9 AMP cordless with a very high torque rating
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Oka
Has thanked: 0
Been thanked: 0
Oka
Post by Oka » Mon Nov 04, 2019 8:12 am
I wonder why my heavy duty electric impact wrench won't loosen the lug nut and these cordless can.
Thought it would have been the opposite.
https://www.youtube.com/watch?v=vAGhD91tmtE
https://www.youtube.com/watch?v=RmcdNDkp5Sw
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 42 times
vtl
Post by vtl » Mon Nov 04, 2019 8:31 am
Because in US we have 110v. With typical 7 Amps it is only 770 Watts of peak power. Modern batteries in cordless tools allow peaks well north of 1000 Watts.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
velorider
Year and Model: 2005 S60 T5
Has thanked: 1 time
Been thanked: 7 times
velorider
Post by velorider » Wed Nov 06, 2019 6:19 am
I have an air impact gun, and recently added harbor freights new high flow disconnects. For $5 it's a pretty significant improvement. I never had issue before but after a lot fewer hammer hits before the bolt wizs off.
RickHaleParker
Been thanked: 374 times
RickHaleParker
Post by RickHaleParker » Wed Nov 06, 2019 7:08 am
Your Trades Pro Impact Wrench is only 240 ft. lbs of torque.
For breaking loose you need a big boy like this, 1050 ft. lbs of bolt breakaway torque. $100.00 at Harbor Freight.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
1997 S90, B6304S, AW30-42, Bosch Motronic 4.4 - Sold
