Hi all,
I picked up a 2008 S80 T6 with 100K miles, I have one last problem I am trying to solve and looking for guidance.
Drivers side BLIS doesn't work and I get BLIS service needed. When I pulled the code I get B118C04
Does anyone know how to go about diagnosing this?
thanks much
Drivers side BLIS issue with Code B118C04
- RickHaleParker
- Been thanked: 979 times
It thinks the Left Camera Module (LCM) has a internal fault. It could be water ingress. Try cleaning the connector in the door.
Active
Past
Past
I took the door panel off, green connector looks good. I also checked the green/white wire with an oscilloscope and there is serial communication to the Left hand camera, however I don’t know the protocol so not sure if the camera is responding.
Is there anything else I should look at before spending the $$ on a new camera?
Thanks much for the help
- RickHaleParker
Power, ground and data all three from the DDM, covers all the I/Os.bans25 wrote: 05 Nov 2019, 20:35 Is there anything else I should look at before spending the $$ on a new camera?
Active
Past
Past
- 1599 Views
Last post by kcodyjr
- 1691 Views
Last post by AndyV70
- 2935 Views
Last post by jlong8
- 1573 Views
Last post by Medo65
- 1312 Views
Last post by PoppySheaf
