1. Has anyone put a mesh filter of sorts on top of the Volvo trunk drain holes to prevent leaves/wood etc from going down the holes? If so, how'd you do it?
2. I need all the clips for the large hood gasket. Any suggestions for good ones? Not sure if there are better ones than stock Volvo parts.
Thanks!
850GLT Drain Holes and Hood Gasket Cips
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
1. I'd try to glue the mesh with sealant, shoe goo ir alike.
2. I doubt there is an aftermarket clip. This would be a typical junkyard or dealer item if they still have it.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 317 times
- Been thanked: 531 times
Yup, definitely something to get either at the junkyard or see if you can order them through Volvo if you don't mind spending a little extra money to have brand new ones.
- Has thanked: 2210 times
What hood clips are you talking about? The ones that hold the sound deadening pad to the hood? If so the like the guys said it is a junkyard run or buy from dealer. I did buy some a couple of years ago as non in junkyards locally at the time.
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Not the sound pad, just the rubber gasket up front.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- RickHaleParker
- Been thanked: 980 times
The T shaped clips that hold the Sealing strip on are Volvo Part number 9133073. They are Multi Purpose Clips and the same ones used for the sound pad, some models used them on the upper radiator panel.
You can get Genuine Volvo and After Market. The After market are as low as $5.00 for a pack of 25 free shipping. The vendors that have Genuine Volvo are pricing them at $2.50 - $4.00 a clip + shipping.
The Sealing strip used 15 of the clips. Genuine Volvo you are looking at $40 - $60 for something that is out of sight and out of mind. I would go with the After Market. They are good enough for FCP Euro and IPD+ ....
The After Market are push to lock type. That is you put them in the hole them push the pin down to lock them in place.
You can find them on FCP Euro, IPD+, eBay and Amazon, search for 9133073.
Active
Past
Past
viper69
Thanks a lot everyone, and thanks Rick!RickHaleParker wrote: 05 Nov 2019, 06:02The T shaped clips that hold the Sealing strip on are Volvo Part number 9133073. They are Multi Purpose Clips and the same ones used for the sound pad, some models used them on the upper radiator panel.
Volvo 850 GLT 1995
- 12 Replies
- 7617 Views
Last post by viper69
- 1706 Views
Last post by rspi
- 13 Replies
- 6238 Views
- 1282 Views
Last post by slickdizzy
- 822 Views
