Did you know? 🤔
Access to Front Passenger Seat Belt on ‘03 S60?
2001 - 2007 XC-70
Mathyou
Year and Model: 2003 S60
Has thanked: 0
United States of America
Mathyou
Post by Mathyou » Mon Nov 04, 2019 4:31 pm
Hello! I’m looking to replace a frayed seatbelt (front passenger) on my kiddo’s 2003 S60, and I’m not getting too far removing the panels. Anyone have experience? The videos I’m finding online don’t cover her model.
The seats are manual, so I suspect I need to remove the lever handles first. Is this as simple as popping a release (I think I see one, but I can’t get it to budge).
Thanks in advance!
velorider
Year and Model: 2005 S60 T5
Has thanked: 1 time
Been thanked: 7 times
velorider
Re: Access to Front Passenger Seat Belt on ‘03 S60?
Post by velorider » Wed Nov 06, 2019 6:24 am
Not sure about the manual seats, but the automatic seats the plastic on the side of the seat rotate up from the back. The hard part is the b Pilar plastic. Be very careful and best do it on a warm day so the plastics not so brittle. I've removed the b-pillar plastic a few times and it's trial and error. Maybe someone knows a secrets.
Mathyou
Has thanked: 0
Mathyou
Post by Mathyou » Wed Nov 06, 2019 7:23 am
Sadly, while I can pop the panel up in the back and even shift it around, it appears that the manual levers are keeping it in place near the front. Also sadly, I’m in MN where it’s between 20 and 40 degrees F, so I’m being extra careful!
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 56 times
vtl
Post by vtl » Wed Nov 06, 2019 7:41 am
There's a small torx screw that you need to undo first.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 0
Australia
darylrobert
Post by darylrobert » Thu Nov 07, 2019 9:41 pm
sounds like the setup is different to a xc70, are you sure you cannot see the single torx bolt from the rear of the seat. Also the pillar trim is easy to break, on the xc70 you simply pull it out from the clips. Remember the seat belt has electrical tensioner, from memory i think like SRS airbag stuff there are some precautions on dealing with those in terms of swapping from car to car.
Mathyou
Has thanked: 0
Mathyou
Post by Mathyou » Thu Nov 07, 2019 10:07 pm
I’m away from home for a few days, but I’ll look when I’m back and post a pic if I can’t find the torx screw. Thanks for the help so far!
Mathyou
Has thanked: 0
Mathyou
Post by Mathyou » Sun Nov 24, 2019 11:08 am
Wanted to loop back in case anyone else has this issue. The plastic handles come off by release. There’s a notch that needs to be lifted up - I used a thin, flathead screwdriver - and pulled off. Once they were both off, the panel popped up then off as seems standard. The belt itself has a metal button that needed to be depressed, then slid off.
My issue now is removing the B pillar to access the upper seatbelt. It doesn’t seem to come off like other models (no obvious release). So pry tools are ready!
These users thanked the author Mathyou for the post:
matthew1
