Did you know? 🤔
Headlights Restored
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 34 times
Been thanked: 76 times
United States of America
MoVolvos
Headlights Restored
Post by MoVolvos » Tue Nov 05, 2019 9:22 pm
EDIT: I confess after looking at those pictures I noticed that I do out of laziness not polish the side of the lenses as much so the fine cracks and remaining yellowish color :roll:.
I will soon try this on the 2008 C30 T5. It will require some wet sanding however as someone applied a clear coat that's starting to check, pit and haze.
As this 03 Odyssey gets older I've been having to clean the lens every year for the last 5 or 6 years. Tried them all, none acetone nail polish remover, tooth paste, WD40, transmission fluid, paint thinner than wax, this besides store bought kits and rest of the usual Youtube offering.
Some of the things dried the lens while others melt / softened it a little so it was hard to work with. This year it's 91% alcohol for cleaning / rubbing with an old sock and then Mothers Mag & Aluminum Polish. So far this has been the easiest, safest and provided the best result with a little elbow grease. Did not start to document this till I saw the results on the driver's side.
https://www.amazon.com/Mothers-05101-Ma ... 90&sr=8-10
Pictures are of:
Passenger side after a very thorough cleaning with the 91% Walmart alcohol. The old sock is all brown and yellow. There are two photos of the Driver's side lens. One is after one polish with Mothers, the other approximately the 4th application. All told about 10 to 15 minutes per side. Keep in mind this is the OE 2003 Lens and the interior of the lens is starting to deteriorate.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
RickHaleParker
Has thanked: 3 times
Been thanked: 574 times
RickHaleParker
Re: Headlights Restored
Post by RickHaleParker » Wed Nov 06, 2019 6:09 am
On plastic lens I wet sand then with 1500 - 2500 grit.
2500 - 3000 grit on the reflector might help if the plating is still there.
If your feeling bold, you might consider trying a $20.00 Spray on Chrome Concentrate Solution.
I have no idea how it would hold up or perform.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
MoVolvos
MoVolvos
Post by MoVolvos » Wed Nov 06, 2019 9:32 pm
RickHaleParker wrote: ↑
Thanks! I purchased a set of sand paper awhile back and hope to take care of the C30 lens during the holidays. The interior reflectors are still good on both the 03 S80 T6 and 03 C30 T5. In order to get inside you have to part the lens so I'm not so incline to do that. The 98 S70's were easy to get into but no longer owned that car.
https://www.amazon.com/gp/product/B07DH ... UTF8&psc=1
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Nov 07, 2019 11:17 am
MoVolvos wrote: ↑
Work the paper in a circular motion, wash periodically.
MoVolvos
MoVolvos
Post by MoVolvos » Thu Nov 07, 2019 10:35 pm
MoVolvos wrote: ↑
I saw a few videos recommending working horizontally, vertically then diagonally. The circular is during final polishing.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Nov 08, 2019 3:08 am
MoVolvos wrote: ↑
I recommend just circular because one is less likely to experience complications
Straight sanding is less work for removing a rough surface, it cuts faster, but can leave visible scratches and can end up removing more material. Circular is to remove any visible scratches.
You can do straight sanding then remove any visible scratches with circular or you can start off with circular not produce visible scratches and minimize the material removal.
Starting off with circular will require more elbow grease but gets better results.
Finish with a UV protective coating to maximize the time before this needs to be done again. Use light coats so it lays down flat and does not distort the optics.
MoVolvos
MoVolvos
Post by MoVolvos » Fri Nov 08, 2019 11:38 am
MoVolvos wrote: ↑
The explanation for the circular motion makes sense. Do you mean paint in a can as a clear coat with UV coating? I would have to alcohol the finished lens to remove any Mothers residue which will probably dull it a bit.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Nov 08, 2019 2:18 pm
MoVolvos wrote: ↑
1. Do you mean paint in a can as a clear coat with UV coating?
2. I would have to alcohol the finished lens to remove any Mothers residue which will probably dull it a bit.
1. Any clear coat with UV protection.
2. After wet sanding .... is Mothers that bad?
MoVolvos
MoVolvos
Post by MoVolvos » Fri Nov 08, 2019 6:41 pm
MoVolvos wrote: ↑
1) Thanks
2) I see, you were thinking wet sanding and then UV clear coat whereas I was thinking wet sanding, Mothers to polish then spray the clear coat. That meant removing the Mothers coating for proper adhesion.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
