Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
New V70 R-design owner need help
- Year and Model: 2010 V70 R-design
- Has thanked: 0
- Been thanked: 0
Hello folks. My name is Abe, always had a love for wagons my first was a Saabaru, then Legacy GT, now my first Volvo a 2010 V70 R-design. As soon as i saw one had to have it. Bought the car 2 months ago with 98K miles, has been great until we had a lot of rain and my passenger footwell and rear passenger side footwell became all well. Did some research and read the drain hose in sunroof is culprit. So took some compressed air and cleaned it out best i could and stuck a long wire to push out any debris. Decided to have my local Volvo dealer take a look as well to be safe and on the way there my ABS maintenace light came on. So Volvo folks said for the drain issue the neck and nipple where the water exits is gone and needs to replace those parts and the tube, cost for that $1,533! According to them they have to remove dash to get to these parts which was not mentioned in any of the posts. For the ABS issue they determined a sensor needed to be replaced that controls the belt tensioner, cost for that $900.00! So looking at $2,433 for total damage. I knew Volvos are a bit expensive to work on but $1500 for water drainage parts?? Do these prices sound justifiable? I love this car but there seem like a exorbitant amount can these issues be rectified in a less costly way?
- MoVolvos
- Year and Model: 03S80T6~08C30T5
- Has thanked: 23 times
- Been thanked: 44 times
Re: New V70 R-design owner need help
From TBSs Carcomplaints.com
Maybe the water is entering else where? Did they remove some interior trim to look?
https://www.carcomplaints.com/Volvo/V70/2010/tsbs/
STRUCTURE:FRAME AND MEMBERS
TSB #TJ-20698
NHTSA ID #10044280
MAY 29 2012
Additional Info:
How to Fix
Summary: VOLVO: WATER MAY ENTER BULKHEAD AREA FROM RUNNING DOWN WINDSCREEN DUE TO AN INACCURATE ARCH WELDING AND WATER FLUSH NOISE IS AUDIBLE WHEN DRIVING AROUND A CORNER. *PE
TSB #TJ-20698
NHTSA ID #10044280
MAY 29 2012
Additional Info:
How to Fix
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- MoVolvos
On my 03 S80 T6 I opened the sunroof and slowly poured water into the drain holes to see if water came out under the car and it did.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 9 times
- Been thanked: 7 times
You can fix it yourself but a Volvo dealership charges atleast $135.00 an hour.
The ABS sensor doesn't make sense to me though. For the drainage issues you should remove some of the trim on that side to pull up carpet in front footwell. The get someone to pour water down the drains and watch where its coming from then repair.
If U Wanna Play U Gotta Pay!!
- 10 Replies
- 550 Views
Last post by June
Tue Feb 26, 2019 6:47 am
New owner 2005 V70....need help with Starting
by Pomial » Sun Apr 16, 2017 4:15 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 7 Replies
- 519 Views
Last post by oragex
Mon May 01, 2017 4:44 am
95 Volvo 850 Turbo Wagon - New Owner Lots of issues. Need help.
by fzr1483 » Wed Jun 08, 2016 9:32 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 4 Replies
- 728 Views
Last post by dubsetter
Wed Nov 23, 2016 10:08 am
New 94' 850 owner need help with codes/stalling
by SCain » Fri Oct 14, 2016 10:22 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 19 Replies
- 1209 Views
Last post by bmdubya1198
Sat Oct 22, 2016 6:40 am
