Tried to use injector cleaner tool at the schrader valve Topic is solved
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 12 times
Post by 800artfreed »
I have an external fuel injector cleaner tool. It is the one that uses air pressure to force cleaner into the injectors through the fuel rail while running the engine. You have to remove the fuel pump relay. I successfully did this on my 1999 S70-GLT non-return fuel system but the 1998 is a return style fuel system. The procedure is to set up the air pressure at less than the fuel pump pressure to prevent the cleaner from being forced back to the fuel tank. I used 40 psi at the cleaner connected to the schrader valve.
Unlike the 1999, on the 98 I heard a strange vibrating (moaning) noise and the car did not run. BTW because of the cable based throttle mechanism on the 98 it is more difficult to attach an adapter to the schrader valve (90 degree connector would be helpful). I took out the valve core and clamped an open ended fuel hose adapter line in my kit to the schrader valve allow the hose to clear the throttle cable bracket.
When the engine did not run I put everything back together. When I went to empty to injector cleaner container it was EMPTY! The strange noise I heard was the cleaning fluid being pushed back through the return line and fuel pressure regulator!
Does anyone know what the fuel rail pressure is at idle on a 1998 S70-T5? Or does anyone have other hints on using this type of tool on a 1998? It worked great on the 1999 S70-GLT. Just wish it was as easy on the 1998.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 179 times
Re: Tried to use injector cleaner tool at the schrader valve
Post by bmdubya1198 »
Hmm... I must admit, I've never heard of one of these injector cleaners. Interesting.
Rail pressure on a '98 should be around 43 PSI, if the information I've seen is correct.
'00 V70R Venetian Red/Charcoal M56 Swapped 199k
'03 S60 2.4T Silver/Black 117k
'07 XC90 V8 AWD Sport Titanium Grey/Black 174k
'91 944 Turbo Dark Green/Beige 175k
'92 245 Base White/Beige 249k
'99 BMW 528i
'01 Mountaineer 5.0
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
misha
Has thanked: 59 times
Been thanked: 163 times
Post by misha »
It is correct.
-43.5psi on 1st prime without starting the engine
-at idle ...everything around 35psi is acceptable
-43.5 psi at WOT
For FPR at fuel rail (M4.3,LH 3.2 jetronic).
M4.4 management,according to Volvo,must have a constant 43.5psi all the time.
It have FPR near the fuel filter and just fuel pressure damper at fuel rail.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
800artfreed
Thanks for the info. I will run a test with the cleaning machine hooked up to see what it shows as the operating pressure at idle on the rail. Then I will set the air pressure supply for 5psi lower then that. I will use gasoline to test operations so as to not waste another $12 bottle of cleaner. If that works I will do the cleaning process with the injector cleaning chemical.
Does the return line have a soft rubber section that can be clamped shut before the FPR?
Today the temperature is in the 30s so I will try something tomorrow when it's a bit warmer. Cheers.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
800artfreed
I reread misha's post. Thanks for the information. I believe the critical information is at idle the rail pressure is only 35psi. I was setup at 40psi. So I can see that with the vacuum levels applied to the FPR it opened up and allowed all the cleaner to go back to the tank. As I posted above I will run some tests and report back. Thanks again.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
misha
Post by misha »
'97 & '98 s,v70 T5 and n/a are ALL M4.4 from the factory.
So....fuel pressure should be constantly 43.5 psi all the time.
Variations in fuel pressure are for M4.3 and LH 3.2 Jetronic which have FPR on the fuel rail.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bmdubya1198
Also, you may have the regulator on the back left corner of the engine bay, just above the steering rack. Just follow the fuel line back.
That could possibly be an issue if your fuel pressure is low.
'99 BMW 528i
'01 Mountaineer 5.0
800artfreed
Re: SOLVERD: Tried to use injector cleaner tool at the schrader valve  Topic is solved
Just catching up on this post. I lowered the air pressure on the injector cleaner tool to below 30 psi. Everything worked as it should. The engine ran at idle and the cleaner was passed into the injectors, not back to the fuel tank. Thanks everyone for your input.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
