Did you know? 🤔
Whats this part called and why does it whine? Topic is solved
CIK7
Year and Model: 1998 Volvo V70 XC
Has thanked: 25 times
United States of America
CIK7
Post by CIK7 » Fri Nov 08, 2019 11:47 am
I have no clue what this item is, but I would like to know. Also it whines whenever i start driving the car in the morning or when it's been sitting a while. It doesn't happen much except in morn time.
1998 V70 XC (selling electric driver seat, PM me)
Future upgrades: 18T, Versatility CC visuals, T5R paint/rims, logo/badge delete excl grille
If you have a 98-00 V70, interested in getting 'interior remodeling' ideas, PM me. I used software to design some woodwork I want to refit my XC with. Satin nickel on dark walnut with shag.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 23 times
Been thanked: 41 times
MoVolvos
Re: Whats this part called and why does it whine?
Post by MoVolvos » Fri Nov 08, 2019 11:52 am
SECONDARY AIR SMOG PUMP AIR PUMP FOR VOLVO C70 S70 V70 9179271
https://www.ebay.com/itm/SECONDARY-AIR- ... 5f9347a29b
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Has thanked: 8 times
Been thanked: 146 times
Canada
Re: Whats this part called and why does it whine?  Topic is solved
Post by scot850 » Fri Nov 08, 2019 12:04 pm
This helps to reduce emissions for the older cars when engine is cold. It forces more air into the cat when it is cold.
Basic flaw with the system is Volvo put the control valve by the exhaust manifold. Over time the diaphram in the valve fails and sticks open and allows condensation to drain down the tube to the pump itself filling it with water. Eventually the pump rusts and fails. The poor design is aggravated by there being no drain hole on the pump for the moisture to wick out. I drilled a small 1/8" hole in the bottom of the casing when I replaced it.
Depending on which state you are in you can do a fairly simple delete of the pump using a resistor (or is it diode?) in the wiring to fool the car into thinking it is there. There are several threads on the subject. If you have to keep it there are/where people re-building them and selling on Ebay at one time for around $120 or so. That was a few years ago.
Either way, you can remove the valve and check it out, or leave it in place and when the engine is warm, remove the pipe to the pump from the pump and try and suck on it. If you can then the valve has failed.
These users thanked the author scot850 for the post:
CIK7
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
850oldschool
Year and Model: 1995 850 NA
Has thanked: 0
Been thanked: 3 times
850oldschool
Post by 850oldschool » Fri Nov 08, 2019 12:39 pm
CIK7 it's amazing that you still have a working pump!
Scott, how long have you been running the pump with the drain hole? Is this really the simple effective solution? I live in a cold climate, my air pump is dead, and the car stinks pretty bad when it's cold, so I'd like to get the system working again.
CIK7
CIK7
Post by CIK7 » Fri Nov 08, 2019 5:18 pm
So does the whining mean it's doing its job? My car stinks really bad of gas actually.
crlande
Year and Model: 240DL;850;S70
Has thanked: 0
Been thanked: 14 times
crlande
Post by crlande » Fri Nov 08, 2019 5:49 pm
Whining for a few seconds after start up is what it should do. It winds up then winds down and stops. Now if the little guy is squealing or screeching or throws a code then you are having issues.
These users thanked the author crlande for the post:
CIK7
Has thanked: 0
Been thanked: 100 times
Post by cn90 » Fri Nov 08, 2019 6:14 pm
Delete the pump and put a diode in.
Info in forum.
These users thanked the author cn90 for the post:
CIK7
850oldschool
Has thanked: 0
850oldschool
Post by 850oldschool » Fri Nov 08, 2019 9:10 pm
Info in forum.
Do you use a remote starter, and finish your coffee while the cat warms up? Mine smells really terrible after a cold start. Like, girlfriend yelling "I hate this stinky car!" bad. It sounds like CIK7 has a similar problem.
Has thanked: 69 times
Been thanked: 220 times
Post by erikv11 » Fri Nov 08, 2019 9:29 pm
I have deleted it on 3 cars now via the diode method, and never had a smelly cat converter. Something is wrong with your exhaust, it is irrelevant to the air pump. Nor does the air pump have anything to do with the car running rich (smelling like fuel) or lean, those are from other issues.
Remember, about half of the 96-98 cars have air pumps, half don't. To turn off the air pump in the tune (then no diode is required) you just disable the air pump routine, without touching any other part of the engine management like air:fuel mix etc.
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
Post by erikv11 » Fri Nov 08, 2019 9:32 pm
Drilling a small hole will help prevent a pump from dying, but will do nothing for a dead one.
If you insist on fixing the pump then step one is replacing the SAS valve, step two is installing a working pump. You don't need to drill a hole if you get a new SAS valve but you can.
'96 855 NA, 140k
'06 S60 R, 160k
