Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
How do I counterhold IPD Hd endlinks Topic is solved
- Year and Model: 850 Turbo Wagon 1994
- Has thanked: 0
- Been thanked: 0
Anybody have a good method to counter hold the IPD front endlinks ? I don't want to tear the boot !!
- Has thanked: 0
- Been thanked: 109 times
Re: How do I counterhold IPD Hd endlinks
Any photos?
If there is a place for Allen or Torx key, then use it.
On the back side near the rubber boot, the Lemforder is a flat part that allows a thin 16-mm bicycle wrench to fit.
If you have air tool, then zip it in. Don't overkill it.
- Year and Model: 1998 V70 T5T
- Has thanked: 0
- Been thanked: 0
Are you willing to describe what you did that worked? I will be doing something similar soon and would benefit from your solution. Thanks.
Now:
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 229 times
- Been thanked: 756 times
Soak them in the PB Blaster a week before you go after them
I can bring my cordless Bosch and zip them off - that’s easiest.
Back up is a Dremel with the FG reinforced cutoff, takes 1 minute to cut off nut
Link To Volvo Glossary
- oragex
- Year and Model: S60 2003
- Has thanked: 89 times
- Been thanked: 209 times
The lower nut won't come off because it has a tiny T25 torx, the torx bit will shear well before the nut will start turning. As above, dremel/grinder and off it comes. The upper nut may work with the torx (If replacing only struts) - it has bigger torx T40 but it won't be easy - one small trick is to turn the nut with the ratchet juust enough to break it loose, like 15 deg - without tearing the boot, then attack with the wrench and torx. Clean well the visible stud treads - will help turn the nut easier once it starts. As above, PB or Liquid Wrench help a bunch but 1-2 weeks in advance. May attach a second wrench for leverage www.youtube.com/watch?v=d7f5l_d0Eq8
Anyone in here have the IPD Sway Bar Endlinks on there S70
by AhmedS70 » Fri Jun 03, 2016 1:15 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 7 Replies
- 696 Views
Last post by E Showell
Sat Jun 04, 2016 11:55 am
2006 V70 rear swaybar endlinks ?
by GlennG2759 » Wed Aug 28, 2019 3:10 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 13 Replies
- 357 Views
Last post by GlennG2759
Fri Aug 30, 2019 5:09 am
Passing emission test: iPD flash vs ARD and others
by biohazrd76 » Wed Jan 06, 2016 3:24 pm » in Performance, Tuning & Aftermarket - 1 Replies
- 3357 Views
Last post by precopster
Sat Jan 09, 2016 9:22 pm
Question about Front IPD Anti Sway Bar Mount Kit (98 S70)
by theWIFES_S70 » Wed Mar 09, 2016 10:01 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 10 Replies
- 707 Views
Wed Mar 09, 2016 11:07 pm
