2002 S60, about 170,000 miles.
My car started making a screeching sound when making a tight turn, such as turning into a parking spot. It sounds like it is coming from the left front.
It screeches with or without brakes.
Normally, I don't hear it when the car has been sitting for a while and is cooled down. So leaving for work, no screech. Get to work, screech.
My mechanic has looked a couple times but can't find anything. The bearing seem find. The brakes are fine.
Any thoughts?
Screeching sound while turning
iastoddard
- Year and Model: 2007 xc70
- Has thanked: 14 times
There is a similar noise from a generic power steering pump. It is from the fluid cavitating. Do you know that you are not making this?
2007 (silver + black leather) XC70, bought used with 156000+ miles
Front clip seems to have damage, no right fog light.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Another possibility if you have those?
Yaworski
- Year and Model: 2002 S60
- Has thanked: 5 times
- Been thanked: 3 times
The noise only happens when the car is moving. I would think that steering pump noise would happen with car moving or sitting still.iastoddard wrote: 10 Nov 2019, 21:39 There is a similar noise from a generic power steering pump. It is from the fluid cavitating. Do you know that you are not making this?
Also, sometimes the noise happens when the steering isn't at or near full lock.
iastoddard
Aha. Not near full lock counts this symptom out. Sorry for misleading.
- SuperHerman
- Been thanked: 207 times
I would check your power steering - look for leaks and fluid level and condition.
Then I would look at the bearing that is on the steering column. You need to remove the plastic piece and pull back the carpet. This is a common source of noise, but I wouldn't call it a screech. Worth a look.
Yaworski
I would think that would make noise while turning the wheel. This noise happens when the car is turning but the wheel is steady.SuperHerman wrote: 11 Nov 2019, 21:42Then I would look at the bearing that is on the steering column.
- SuperHerman
As I cannot see, hear or touch your car - I suggested a common source of steering noise on almost all Volvos. The easy way to eliminate it as the source is to take 5 minutes and look.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Where is your spouse when this noise happens? Could it be coming from their mouth? How's your driving? Have you had a refresher course lately?Yaworski wrote: 10 Nov 2019, 08:10My car started making a screeching sound when making a tight turn.....
Just a thought.....
Carry on.
- MoVolvos
That reminds me! When my boys were young they always had this invisible steering wheel in their hands. When I made tight turns they screeched while turning and leaning. I show them on Youtube the consequences of bad and fast driving. Now that they both drive I've taught them what a car can potentially do making a tight turn for safety reasons and skill improvements. Screeching the tires would take away the car privileges. Once or twice at this one particular turn however, I only screeched them slightly and carefully to show them where they don't want to go even though the capability is there.BlackBart wrote: 30 Nov 2019, 23:35Where is your spouse when this noise happens? Could it be coming from their mouth? How's your driving? Have you had a refresher course lately?Yaworski wrote: 10 Nov 2019, 08:10My car started making a screeching sound when making a tight turn.....
Just a thought.....
Carry on.
- 1991 Views
- 4837 Views
Last post by theWIFES_S70
- 22 Replies
- 3213 Views
Last post by smacknab
- 1005 Views
Last post by motormikeyman
- 785 Views
Last post by tincanman
