2005 R Seat into 2003 V70 - How To
2001 - 2007 XC-70
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 647 times
Been thanked: 272 times
Post by matthew1 »
Transposed (ok, copied) from Rob's post on Facebook MVS.
The Problem: A simple whole-seat swap will trip airbag, and CANBUS SRS codes.
The Solution: Swap skins and pads.
Sometimes you just want a really comfy seat. I don't recommend doing this.
So onto the fact I did this.... I swapped the skin and cushions from an 05 S60R seat to my 03 V70 seat. The seat heaters are the same connectors, which is rather nice, but I had to use the old airbag, and electronics due to the CANBUS on this car.
Not bad once you get in a rhythm, but a bunch doesn't fit the way you'd expect. The back adjustment knob is higher on an 05, so had to cut the leather a little for it to fit the 03. Also you'll have to swap the head rest skins. I haven't yet, but the 03 has a wider footprint then the 05. To remove the head rest, feel at the back of the seat, where the top seam is, like 6 inches above the pocket, and "pop" it. Takes a lot of feeling around, took me a little.
Other things to note, I had to extend the connector for the 05 back heater to hook up as well. I used a grinding wheel, and a drill to level out the seat cushion springs from the 05 for mounting, hence, the self tappers. 05 cushions just clip instead of hog rings.
But again, I don't recommend this headache, unless you're like me, and everything you drive needs to be comfy!!
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Has thanked: 376 times
Been thanked: 1176 times
Re: 2005 R Seat into 2003 V70 - How To
My hands ache just looking at those pictures
Link To Volvo Glossary
matthew1
Site Admin
Post by matthew1 »
So then do SRS codes make your mind ache? :lol:
Also -> Amazon link
Oh crap, slow can Bus speed in 2003. That’s not going to work, is it?
