Transposed (ok, copied) from Rob's post on Facebook MVS.
The Problem: A simple whole-seat swap will trip airbag, and CANBUS SRS codes.
The Solution: Swap skins and pads.
Sometimes you just want a really comfy seat. I don't recommend doing this.
So onto the fact I did this.... I swapped the skin and cushions from an 05 S60R seat to my 03 V70 seat. The seat heaters are the same connectors, which is rather nice, but I had to use the old airbag, and electronics due to the CANBUS on this car.
Not bad once you get in a rhythm, but a bunch doesn't fit the way you'd expect. The back adjustment knob is higher on an 05, so had to cut the leather a little for it to fit the 03. Also you'll have to swap the head rest skins. I haven't yet, but the 03 has a wider footprint then the 05. To remove the head rest, feel at the back of the seat, where the top seam is, like 6 inches above the pocket, and "pop" it. Takes a lot of feeling around, took me a little.
Other things to note, I had to extend the connector for the 05 back heater to hook up as well. I used a grinding wheel, and a drill to level out the seat cushion springs from the 05 for mounting, hence, the self tappers. 05 cushions just clip instead of hog rings.
But again, I don't recommend this headache, unless you're like me, and everything you drive needs to be comfy!!
2005 R Seat into 2003 V70 - How To
- Has thanked: 713 times
- Been thanked: 309 times
- 74484062_10157203641633876_7080018721464385536_n.jpg (38.94 KiB) Viewed 39 times
- 74484770_10157203641708876_6622072180035289088_n.jpg (54.09 KiB) Viewed 39 times
- 75540163_10157203641778876_779308029014179840_n.jpg (35.02 KiB) Viewed 39 times
- 77124316_10157203641823876_6942029698645884928_n.jpg (46.36 KiB) Viewed 39 times
- 75580426_10157203641868876_5132464667221819392_n.jpg (39.62 KiB) Viewed 39 times
- 72257954_10157203641898876_1550911049908092928_n.jpg (47.59 KiB) Viewed 39 times
- 76954517_10157203641963876_8007996979005095936_n.jpg (71.17 KiB) Viewed 39 times
- 72279873_10157203642013876_2433632622870528000_n.jpg (44.22 KiB) Viewed 39 times
- 75485169_10157203642103876_6233410809779716096_n.jpg (60.89 KiB) Viewed 39 times
- 74666248_10157203642148876_8649967381415723008_n.jpg (53.59 KiB) Viewed 39 times
- 74842684_10157203642193876_8252697689813155840_n.jpg (50.54 KiB) Viewed 39 times
- 75302641_10157203642258876_5704843362348040192_n.jpg (45.99 KiB) Viewed 39 times
- 74522296_10157203642298876_3566128147780861952_n.jpg (24.38 KiB) Viewed 39 times
- 71789703_10157203642343876_728140339860209664_n.jpg (37.74 KiB) Viewed 39 times
Also -> Amazon link. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 440 times
- Been thanked: 1333 times
Re: 2005 R Seat into 2003 V70 - How To
My hands ache just looking at those pictures
Link To Volvo Glossary
So then do SRS codes make your mind ache?
Oh crap, slow can Bus speed in 2003. That’s not going to work, is it?
