2007 S60 Radio no power when ignition switch on [fuse 28 cem] Topic is solved
FarmallM51
Year and Model: 2001 S60
Been thanked: 5 times
Post by FarmallM51 »
I had to remove the radio from this car but when I reinstalled it there is no power to the violet wire on the green connector. As far as I can determine, this is the switched power supply. I do have power & ground to the red & brown wires on the same plug. Audio fuse #10 is fine. In my 2004 V70 I believe this wire is powered by fuse #15, but my fuses behind the headlight switch stop at #11. Any ideas how I can track this down or wire an alternative switched power?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Check fuse #28 in the CEM under the dash. That is where the violet wire comes from.
Active
Past
FarmallM51
THAT'S IT! Thanks. A bear to get to, but it was the one blown.
