P2 PEM checkout?
iastoddard
Year and Model: 2007 xc70
Has thanked: 14 times
Post by iastoddard »
I have a 2007 XC70 throwing a P0089 code. I have replaced the sensor on the fuel rail, and the fuel filter. I am in the middle of system component checkout and am looking for PEM diagnostics. I have googled and found nothing helpful. My PEM is in the spare tire well, so probably no corrosion issues.
Can I check it with a multimeter, or do I need an oscilloscope? If former, please lead me to specs? If latter, do I need to get VIDA? I am in Houston TX and would love to talk to someone local about VIDA. I am retired so saving money is paramount.
2007 (silver + black leather) XC70, bought used with 156000+ miles
Front clip seems to have damage, no right fog light.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Checking the PEM off the car is very very difficult.
Your best bet is to find a good used PEM (ebay, junk yard, good known PEM from another car) and swap over.
If the swap fixes the issues, you know the answer.
PS: The corrosion is internal (on the circuit board) of the PEM.
Has thanked: 1611 times
Been thanked: 4075 times
There are details and discussion in the XC90 forum Under user shockwave.
This includes links the o scope waveforms for the CEM ECU and PEM electronics
viewtopic.php?f=9&t=84648
Pull your part number and edit the title so we can search for it here, too, please!
iastoddard
Thank you to @cn90 and @abscate for the good words.
I will try to source the part from rockauto.com or a pick-and-pull.
I have to wait for the 17th to get funds$$$$ for this experiment.
As for the oscope readings, yikes!
I will put part number data in the title as soon as I have it.
Post by cn90 »
The current price of a used PEM on ebay is about $35-$50. Search for a reputable ebay seller.
If you have access to junk yard, then it is about $15, which is what I do: getting spare parts from junk yard in case I need them.
I have stopped going to jy now bc I think I collect too much junk...lol...
There are sellers on ebay that go to jy to buy important parts for cheap, and sell on ebay to make a living...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The one in the trunk its protected from corrosion and also sits vertically so flakes from under the cooling plate wont fall over the control board. But as above, any used one that looks very clean will work, cheap to test. If you have a junkyard close, the second gen S40 V50 has it under the rear seats left side under the insulating material - these are the cleanest
