08 XC90 AWD Disabled
MattGXC9D
Year and Model: 2008 XC90
Post by MattGXC9D »
Hi all! I'm new to the group and was hoping to get some feedback on my AWD system Disabled issue.. I have tried changing the fluid and Haldex filter in hopes that it may clear out but no luck.. I tried putting a scanner to the truck but showed no Codes at all.. fuse is ok. This issue started a few months ago and at first would be intermittent and is now constantly disabled. Any ideas at all?? 200k miles on it. This has been a great vehicle and would love to get this issue resolved being winter and all... Thanks in advance!!!
-Matt
Reason: Edited title. Please, no "HELP"s in titles.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
MattGXC9D wrote: 14 Nov 2019, 11:58 I tried putting a scanner to the truck but showed no Codes at all.. fuse is ok.
Not all scanners can get the Differential Electronic Module (DEM) codes, what scanner did you use? Vida-DiCE recommended.
You can try cleaning the connectors on the Differential Electronic Module.
( Under Truck at the end of the driveshaft, rear axle ).
Check the DEM harness for shorts and opens.
Active
Past
