S70 T5 -- softer ride? tires?
mar601
- Year and Model: 1998
- Has thanked: 34 times
- Been thanked: 5 times
I've had an S70 T5 since 1998 but past few years my 66 years are having a hard time feeling every bump in this car. Want to keep it but wondering if there is anything I can do to soften the ride? I do need new tires so maybe I can start there. Always bought the Michelins that the dealer had in their recommendations for the car which may be more of a sport tire? -- thanks
- Has thanked: 2854 times
- Been thanked: 1332 times
Check out Tire Rack https://www.tirerack.com for reviews on ride. Michelins are not necessarily sporty, and usually not in reality.
Tires are by far the easiest way to get what you want. Tire brand, inflation psi, etc.
After that comes struts, if tires don't do it.
I hear you though. I had a '97 850 T5, and that had a rough factory ride. Our cars are similar if not identical on factory setup.
How many miles do you have on her?
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Your car came with 16" wheels and 205/55/16 tires from the factory.
In general, if you increase the size of the side wall, you get a more comfortable ride.
You can achieve this by going to 15" wheels. The tire size I would recommend for that size is 195/65/15.
This change will make a significant difference and would be less "harsh".
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Interestingly, my 94 T5 wagon is very comfy with its 16 inch wheels. Maybe that is because the shocks and springs are well worn in and my reference 96R with the 17 inch wheels and Volvo sport suspension is really harsh.
But, try to play with the tire pressure. Don't go too low of course, that is dangerous, but a few psi less or more makes alot of difference for me in these P80 cars.
And yes, if looks are not that important to you, 15 inch definitely makes a very comfy ride, as 850LPT suggests.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
mar601
Thanks for that -- I've always had an issue with one of the wheels so will look into that. Really makes a difference you think? If so, I'll do it. --thanks
- Has thanked: 2197 times
- Been thanked: 1850 times
P80 offset is 43mm. Center hub 65.1mm.
First thing to check is if 15" rims clear your calipers. T5 may need 16" to clear if your car is fitted with 300mm rotors.
I am running 17" on my 00 'R' and it is firm but not too bad. Our roads around here are horrible. I removed the Bilstein HD shocks the car came with as way too hard. Fitted Bilstein Tourings and way better.
Talk to somone at say Tirerack and see if they can recommend a tire with softer sidewalls. I run tires at 36psi as lower they wear the outsides down quickly ( Volvo says 32psi). It may also be our elevation. A sports tire will have firmer sidewalls to give a tighter/grippier feel to the steering. Michelins tend to have stiffer sidewalls. Non sport tires will have softer more compliant sidewalls but wont make the steering feel quite so responsive. Oh, I am just a few years younger than you and prefer the comfortable drive!
Buy 15" Volvo wheels with tires off Craigslist. Press the Easy Button on this.
- 2094 Views
Last post by bmdubya1198
- 801 Views
Last post by Sveedy
- 1125 Views
Last post by brayski
- 1132 Views
- 1610 Views
Last post by oragex
