Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
S70 T5 -- softer ride? tires?
- Year and Model: 1998
- Has thanked: 0
- Been thanked: 0
I've had an S70 T5 since 1998 but past few years my 66 years are having a hard time feeling every bump in this car. Want to keep it but wondering if there is anything I can do to soften the ride? I do need new tires so maybe I can start there. Always bought the Michelins that the dealer had in their recommendations for the car which may be more of a sport tire? -- thanks
- Has thanked: 432 times
- Been thanked: 160 times
Re: S70 T5 -- softer ride? tires?
Check out Tire Rack https://www.tirerack.com for reviews on ride. Michelins are not necessarily sporty, and usually not in reality.
Tires are by far the easiest way to get what you want. Tire brand, inflation psi, etc.
After that comes struts, if tires don't do it.
Also -> Amazon link. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
I hear you though. I had a '97 850 T5, and that had a rough factory ride. Our cars are similar if not identical on factory setup.
How many miles do you have on her?
- Year and Model: 96' 850
- Has thanked: 52 times
- Been thanked: 36 times
Your car came with 16" wheels and 205/55/16 tires from the factory.
In general, if you increase the size of the side wall, you get a more comfortable ride.
You can achieve this by going to 15" wheels. The tire size I would recommend for that size is 195/65/15.
This change will make a significant difference and would be less "harsh".
96' 850 sedan, base, auto, pewter/charcoal, 111k miles
99' S70, base, 5-speed manual, nautic blue/ tan, 213k miles
04' V70, auto, ash gold/ tan, 225k miles, daughters car
05' V70, 5-speed manual, loaded, mistral green/ tan, 146k miles
79' Ford Capri S, Euro Spec 2.8 V6, T9 5-speed manual
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Clemens
- Has thanked: 73 times
- Been thanked: 40 times
Interestingly, my 94 T5 wagon is very comfy with its 16 inch wheels. Maybe that is because the shocks and springs are well worn in and my reference 96R with the 17 inch wheels and Volvo sport suspension is really harsh.
But, try to play with the tire pressure. Don't go too low of course, that is dangerous, but a few psi less or more makes alot of difference for me in these P80 cars.
And yes, if looks are not that important to you, 15 inch definitely makes a very comfy ride, as 850LPT suggests.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
- Has thanked: 0
- Been thanked: 0
Thanks for that -- I've always had an issue with one of the wheels so will look into that. Really makes a difference you think? If so, I'll do it. --thanks
- Has thanked: 0
- Been thanked: 0
so when I buy 15" wheels is that all I need to know? are they also sold by width? were there ever Volvo 15" wheels that would be a nice match for the T5 wheels?
- Has thanked: 9 times
- Been thanked: 148 times
P80 offset is 43mm. Center hub 65.1mm.
First thing to check is if 15" rims clear your calipers. T5 may need 16" to clear if your car is fitted with 300mm rotors.
I am running 17" on my 00 'R' and it is firm but not too bad. Our roads around here are horrible. I removed the Bilstein HD shocks the car came with as way too hard. Fitted Bilstein Tourings and way better.
Talk to somone at say Tirerack and see if they can recommend a tire with softer sidewalls. I run tires at 36psi as lower they wear the outsides down quickly ( Volvo says 32psi). It may also be our elevation. A sports tire will have firmer sidewalls to give a tighter/grippier feel to the steering. Michelins tend to have stiffer sidewalls. Non sport tires will have softer more compliant sidewalls but wont make the steering feel quite so responsive. Oh, I am just a few years younger than you and prefer the comfortable drive!
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
2006 XC70
Buy 15" Volvo wheels with tires off Craigslist. Press the Easy Button on this.
Pimping Mom's old ride (S70 T5 Restoration)
by slupul » Tue Mar 08, 2016 1:09 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 4 Replies
- 1210 Views
Last post by bmdubya1198
Wed Mar 09, 2016 8:06 am
Suspension ride / alignment issue
by Baker7 » Sat Mar 05, 2016 12:50 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 4 Replies
- 557 Views
Sun Mar 06, 2016 12:39 pm
- 470 Views
Last post by oragex
Thu Jun 02, 2016 6:03 am
Bilstein TC's installed - Ride Height?
by BackRoadSeeker » Wed Oct 05, 2016 5:28 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 7 Replies
- 580 Views
Last post by erikv11
Thu Oct 06, 2016 3:22 pm
