Ok those is going to be a little weird.
Not long after I got my car I turned off the drl, because why not.
I noticed that when my headlights are on, I’ll occasionally get the bulb failure light to flash on when I hit the brakes. Doesn’t stay on, just blinks quick enough for me to notice, and doesn’t happen every time I hit the brakes. One day I had my wife hit the brakes while I killed and didn’t see any brake lights at all, so I immediately replaced the bulbs thinking they were the culprit, but they weren’t.
Now, whenever this happens I look to see if the lights are lit (usually I can see the 3rd brake light reflecting on trim) and I tap thee pedal again to try to make them come on.
I’m starting to suspect the switch is fucky but could it be at all related to the drl settings?
Thanks!
Brake light issue, need advice 98 v70
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Check the harness going to the rear hatch - you may find broken wires in it.
- default
- Year and Model: 1998 v70 awd
- Has thanked: 1 time
Is there a guide on that someplace? Or a specific place to look? I’m really leery about ripping into this trim if I don’t need towizechatmgr wrote: 16 Nov 2019, 19:59 Check the harness going to the rear hatch - you may find broken wires in it.
Edit: that actually makes a little sense considering my rear sprayer only works when it wants, although the wiper is fine
Edit 2, found the RobertDIY video on it, that man is a blessing
- wizechatmgr
Right above the rear driver's side speaker between that harness and the inside of the actual hatch. In my case I found the rear defroster grid's positive wire was dead and another wire that I cannot remember but I replaced it too.
- Has thanked: 311 times
- Been thanked: 817 times
corrosion at the bulb insertion can also cause that flash of the warning light. can be hard to find
- 253 Views
Last post by Wackneck
- 644 Views
Last post by dosbricks
- 889 Views
Last post by skippyxc90
- 52 Replies
- 10158 Views
Last post by PeteB
- 908 Views
Last post by regent
