Hi!
Is there a working Vida for my car? I read that 2014d is the last working cracked Vida and the 2015a is online based. The 2014d can read/write my car? The 2015a is available on aliexpress,how? My car’s production date is 2015 october. Volvo V60 PHEV TwinEngine.
Thanks!
Vida for my 2015.10 Volvo V60
- RickHaleParker
- Been thanked: 978 times
2014D was released in 2015. It will works on at least some 2015 cars. I don't think anybody knows exactly what the cut off point is.
Don't fork over any money for the 2015A. It is a hacked version of 2014D.
"2015A" is supposed to have to have some databases past 2014 added. Support past 2014 in "2015A" is hit and miss. One guy could not get it to connect to six different 2016 cars. Another got it to connect to his 2017 S60. Most people that paid for it are pissed and call it a scam.
I got a copy of the "2015A" but have not played around with it yet.
↓↓↓ 2014D_RePack ↓↓↓
Active
Past
Past
- RickHaleParker
You could use VDash with a DiCE unit. Your car being a P3, Vdash can crack your CEM and ECU pin through the DiCE unit.
SPA/CMA, P1 & P2 requires opening the CEM, copying the bin and extracting the pin numbers.
I'm still looking into VDash and have not done much with it so far.
With the pin codes, you can do all of the following. (There will be charges for some functions.)
- Diagnostics - read / clear diagnostic trouble codes - DTC's
Resetting service reminder - SRI
Change dashboard computer / radio / phone language
Optimize the engine power
Change car configuration (disable STOP/START, activation Video-In-Motion, add independetn heater function, add cruise controll, add trip computer, change the region USA to EU, activate navigation,...)
Decode PIN for CEM and ECM
Add / remove ignition keys and remote controllers
Pair new SCL and SCU units
Copy / clone almost all electronic modules
Injectors coding
Dataloging
Read READINESS codes
Electronic servicebook
Reminding technical inspection date
Print car status protocols
Driving book in combination with VDD
Update and setting bluetooth P2V2 modules
Active
Past
Past
Thanks for your replies. The fault code read and delete is free in the VDASH? Service reset? if i add some freatures like change language or enable auto light how much i pay for it? (Give or take)
Thanks.
Thanks.
- RickHaleParker
Diagnostics is free. Tunes cost. I cannot explore everything because I have not cracked the pin numbers yet. I will need to open the ECM and read the chip directly. You have a P3, you can crack the pin numbers from with Vdash without removing the ECM.m0rd0k wrote: 17 Nov 2019, 20:49 Thanks for your replies. The fault code read and delete is free in the VDASH? Service reset? if i add some freatures like change language or enable auto light how much i pay for it? (Give or take)
Active
Past
Past
- RickHaleParker
The app has a shopping basket. You always have a opportunity to change your mind before being charged.
Active
Past
Past
- Kara503
- Year and Model: 1996 850 Plat R-Swap
- Has thanked: 17 times
- Been thanked: 6 times
Rick-RickHaleParker wrote: 18 Nov 2019, 16:58 The app has a shopping basket. You always have a opportunity to change your mind before being charged.
Any new insights on VDASH? It's capabilities, reliability, have you run into any issues?
Recently purchased a 2014 s60 and will be picking up VDASH to play with it as well as my 2014D ViDA setup. Would have loved to pick up a 2016 for the 4 cylinder's economy but not having diag capability past a regular OBDII scanner kept me on 2015 or older.
It doesn't look like we have any info at all for VDASH on MVS, would be good to build a thread. Depending on what it can do it could be the path moving forward for shadetrees who own anything 2015+!
96 855 Platinum- Elsa
98 V70R- Goose
06 S40 NA- Hilda
02 VW Jetta TDI wagon- Dizzy
98 V70R- Goose
06 S40 NA- Hilda
alex19860815
- Year and Model: 2010 VOLVO S60
where you bought the VIDA DICE ? i found this ,is it okt ?https://www.obd2sales.com/product/volvo ... iagnostis/? i have been read that the 2014D Dice can work on cracked 2015A software without Dongle . have been any guys tested ?
- 5697 Views
Last post by MoVolvos
- 472 Views
Last post by capkrokus
- 2583 Views
Last post by Johnaldo
- 1896 Views
Last post by Vandalfsens
- 5798 Views
Last post by olddaddy
