Guys;
Mr. Parker was kind enough to post a nice snapshot of the rear left side of the cars relay bay if you will. My most recent problem is that I can't access the right side of the relay box due to the inside body liner or trim. I tried prying or pulling the inner trim to no avail. Do I need to unscrew the whole relay box to get complete access? (See attachment)
2002 V70 Rear Relay/Shunt Removal?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- RickHaleParker
- Been thanked: 980 times
I think this is the answer. Remove bolt, unhook, then pull the whole unit out.
xHeart could tell you for sure, it is his picture.
Active
Past
Past
- NullenVoyd
- Year and Model: 2004 XC70
- Been thanked: 3 times
I'm tempted to say this is nearly identical to the CEM mounting - bolt is for holding the main connector in, and there should be a metal flap on the right behind the carpeted trim that would release the whole module and allow it to slide up and out. This is an educated guess, but still a guess.
- Has thanked: 1611 times
- Been thanked: 4074 times
I’ve had mine out and you have to release some electrical wiring to get slack if I recall
Battery needs to be disconnected first of course, always.
Mr. Detail
I never thought of disconnecting the battery. Only replacing a plug 'n' play relay but I will obey.
If you are just snapping it in/ out, no problem. Removing any component, disconnect negative. The red wires are probably always hot, so putting down the REM onto a metal surface could get interesting
Mr. Detail
Can someone help me with acronym/abbreviations here? "CEM" and "REM".
I want to assume they stand for that relay panel.
DrDan
- Year and Model: 02 V70
- Been thanked: 9 times
REM is the Rear Electronic Module, located in the left hand side of trunk
CEM is the Central Electronic Module, located in the passenger compartment under the dash.
Reading the thread, I wonder why you would want to remove the REM, not the trim panel which prevents access. I don't recall the exact steps, but I think it's mostly folding the seats, removing the floor panels and one screw on the side panel. Not difficult and not much work.
Mr. Detail
DrDan, all I wanted to do was replace a single, potentially worn out relay. The one I was told that operates the left rear fog lamp properly is on the right hand side of the REM and it is blocked by the trim panel. Seems like a stupid location for it since I can't get full access upon opening the access door.
Sorry for the acronym useMr. Detail wrote: 20 Nov 2019, 05:31 Can someone help me with acronym/abbreviations here? "CEM" and "REM".
Main Page >> Problems Fixes >> Resources and Reference >> Glossary
https://www.matthewsvolvosite.com/glossary
- 1887 Views
Last post by EngineeringBloke
- 4390 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
- 11 Replies
- 2801 Views
- 1800 Views
Last post by vtl
