2002 V70 Rear Relay/Shunt Removal?
2001 - 2007 XC-70
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 24 times
Post by Mr. Detail »
Guys;
Mr. Parker was kind enough to post a nice snapshot of the rear left side of the cars relay bay if you will. My most recent problem is that I can't access the right side of the relay box due to the inside body liner or trim. I tried prying or pulling the inner trim to no avail. Do I need to unscrew the whole relay box to get complete access? (See attachment)
Presentation_Relay_Location.pptx
(178.01 KiB) Downloaded 30 times
RickHaleParker
Has thanked: 3 times
Been thanked: 608 times
Re: Rear Relay/Shunt Removal?
Post by RickHaleParker »
I think this is the answer. Remove bolt, unhook, then pull the whole unit out.
xHeart could tell you for sure, it is his picture.
2004 S60R, B8444S TF80 AWD.
NullenVoyd
Year and Model: 2004 XC70
Been thanked: 3 times
Post by NullenVoyd »
I'm tempted to say this is nearly identical to the CEM mounting - bolt is for holding the main connector in, and there should be a metal flap on the right behind the carpeted trim that would release the whole module and allow it to slide up and out. This is an educated guess, but still a guess.
Has thanked: 378 times
Been thanked: 1184 times
I’ve had mine out and you have to release some electrical wiring to get slack if I recall
Battery needs to be disconnected first of course, always.
Link To Volvo Glossary
Mr. Detail
I never thought of disconnecting the battery. Only replacing a plug 'n' play relay but I will obey.
If you are just snapping it in/ out, no problem. Removing any component, disconnect negative. The red wires are probably always hot, so putting down the REM onto a metal surface could get interesting
Mr. Detail
Can someone help me with acronym/abbreviations here? "CEM" and "REM".
I want to assume they stand for that relay panel.
DrDan
Year and Model: 02 V70
Been thanked: 9 times
Post by DrDan »
REM is the Rear Electronic Module, located in the left hand side of trunk
CEM is the Central Electronic Module, located in the passenger compartment under the dash.
Reading the thread, I wonder why you would want to remove the REM, not the trim panel which prevents access. I don't recall the exact steps, but I think it's mostly folding the seats, removing the floor panels and one screw on the side panel. Not difficult and not much work.
Mr. Detail
Re: 2002 V70 Rear Relay/Shunt Removal?
DrDan, all I wanted to do was replace a single, potentially worn out relay. The one I was told that operates the left rear fog lamp properly is on the right hand side of the REM and it is blocked by the trim panel. Seems like a stupid location for it since I can't get full access upon opening the access door.
Mr. Detail wrote: Wed Nov 20, 2019 5:31 am Can someone help me with acronym/abbreviations here? "CEM" and "REM".
Sorry for the acronym use
Main Page >> Problems Fixes >> Resources and Reference >> Glossary
https://www.matthewsvolvosite.com/glossary
