Photo upload attachments are fixed. I broke them inadvertently last night.
How do you say goodbye? - S70, not passing NYS emissions...
Has thanked: 376 times
Been thanked: 1171 times
Re: How do you say goodbye? - S70, not passing NYS emissions...
The exhaust manifold leak is causing the slow OXS code, P0133. Replacing the OXS won’t solve it ( but I’ll have a spare there, too)
The small evap leak is preventing your evap readiness, which is holding up inspection.
I do have a place up here that will pass a Volvo on inspection with no CEL and non-readiness
Link To Volvo Glossary
wheelsup
Year and Model:
Has thanked: 6 times
Been thanked: 4 times
Post by wheelsup »
In my state if the readiness won't come on you can go to the DMV, they look it over and issue a pass. No $$ cost.
1995 850 GLT Wagon w/ 185,000 miles
WhatAmIDoing
Year and Model: 1998 S70 T5M
Has thanked: 66 times
Been thanked: 57 times
Post by WhatAmIDoing »
I think the easy answer is finding a shop that will just pass anyone with no CEL or codes regardless of readiness.
This really just proves how problematic OBD emissions checks are. They don't really tell you anything unless an "important" emission system has failed. Usually they just say not ready, resulting in the owner being pressured by the shop to spend hundreds or thousands of $$$ to "fix" your car so it will pass inspection. The only emissions test that should matter is what comes out of the tailpipe under normal driving conditions.
I still firmly believe yearly inspections are just a scam to make the state and mechanics more money.
'98 S70 T5M - 282,000+mi - forever a project
'99 S70 "AWD" - 220,000+mi - part out :cry:
Knows enough to be dangerous :wink:
No one is getting rich off $14-21 inspections here.
The evap system is arguably the most important as a car that is sitting pollutes more than a running car if it pumps off gas fumes.
OBD was the lifesaver for this as all the misfire stuff is good enough that if the car isn’t triggering OBD codes,it is running clean.
I would be afraid to see what tires and brakes people would run in uninspected states. People will pay their cable bill before replacing tires with no tread
magna224
Year and Model: 850 T5's
Post by magna224 »
There's US states that inspect tires and brakes? I thought that was just a EU thing.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 36 times
Been thanked: 82 times
Post by MoVolvos »
magna224 wrote: Mon Dec 02, 2019 9:02 pm There's US states that inspect tires and brakes? I thought that was just a EU thing.
Cost $30 in 22 counties of NC regardless of shop. OBDII for readiness and the other is safety.
https://www.ncdot.gov/dmv/title-registr ... tions.aspx
Headlights
Accessory lights
Directional signals
Foot brake
Parking brake
Steering
Tires
Horn
Rearview mirror​
Windshield wipers
Exhaust system
Tinted windows, if applicable
Motor vehicles registered in 22 North Carolina counties must also pass an emissions inspection, conducted at the same time as the safety inspection.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Example of nys brake inspection checklist
Brake pedal reserve - brake pedal must have 1/3 reserve
Brake pedal fade - brake must hold for one minute without fading
Power brake unit - check for proper operation
Brake master cylinder - check for leakage and proper fluid level
Disc brake pads - check condition
Drum brake linings - thickness of linings must be at least 1/16 inch on bonded linings or at least 1/32 inch over rivet head on riveted linings, with no loose or missing rivets or lining
Brake drums and/or rotors - check condition
Wheel cylinders and/or calipers - check for leakage
All brake lines and hoses - check for leaks, cracks, chafing, restrictions, and improper support
Parking brake - check for components and function
Brake equalization - test vehicle for a straight stop without significant wheel pull
Year and Model: 2001 V70
Has thanked: 58 times
Been thanked: 127 times
Post by volvolugnut »
Back when Oklahoma had inspections (10-20 years ago), they charged $5. Typically they looked at your tires in a quick walk around. Brakes were good if you did not drive through the rear of the shop. Honk your horn, give them the money and you were out of there.
Now, I see some terrible tires on the road - bald and some hairy with cords showing. No emissions test here either.
It's the wild west.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
RickHaleParker
Has thanked: 3 times
Been thanked: 603 times
Post by RickHaleParker »
Back in the 70s Kansas shops pushed for safety inspections. The State gave in to the political pressure but set the price of the inspection in the legislation. Safety Inspections were repealed a few years later when the shops complained they could not make "enough" at the set price.
That is the last we heard on that subject.
2004 S60R, B8444S TF80 AWD.
Has thanked: 110 times
Been thanked: 325 times
I've lived and owned cars in states with a wide range of smog and safety requirements (CA, NY, and the midwest). My two cents:
$0.01 - the idea of shops or "the government" or anyone else getting rich off of inspections is silly, it doesn't happen and is definitely not why the requirements get put in place. At the same time if the repair shop does the inspection then of course it's fair the shop makes something off it.
$0.02 - inspections definitely make the driving experience safer, by improving the operability of cars on the road.
Safety inspections are a no-brainer, every state should have them.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
