Bought on 7/05/19 from original owner for $3K with 100,050 miles on it. Black leather int.,Thor wheels, & Automatic.
- Spark plugs & air filter changed out
- IPD PCV kit installed, cleaned TB, ran
Berryman thru injectors, new injector o-rings.
- Changed oil & filter 5W/30 Synthetic
- Cleaned MAF
- New front/rear brake pads
- 4 Drain& Fills w/Valvoline Maxlife ATF
- New cabin filter
- New Mayle HD front endlinks, no rear swaybar
- New rear exhaust hanger
- Installed INA Timing Belt Kit w/o water pump & Dayco step. belt. Scary turning that key for the first time.
- New (Hutchison) upper engine torque rod mount, lower trans. mount, and right engine mount.
- New IPD engine crossbar mount poly bushings
- New IPD subframe bushing poly inserts w/new bolts
- Refreshed front struts w/Rein spring seats, Lemforder mount, new bellows, bump stops, and new hardware. Cleaned and painted.
-Installed New Lemforder control arms and ball joints,TRW inner and Delphi outer tie rods.
- Front end alignment 11/13/19
- Things yet to do: Cooling system flush
and fabricate rear muffler hanger. Tang
rottted off muffler
* Mileage as if 11/17/19 103,275
Total spent approx. $1520 in parts $4520 total. I've done all the work myself except for alignment.
** Would not have attempted half of the above work if not for the great advice of some very, very knowlegeable people on this great site.
'06 Volvo V70 NA Willow Green Met.
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
- GlennG2759
- Cleaned MAF
- New cabin filter
- Installed INA Timing Belt Kit w/o water pump & Dayco serpentine belt. Scary turning that key for the first time.
- Replaced front struts Sachs w/Rein spring seats, Lemforder mount, new bellows, bump stops, and new hardware.
- Cooling system flush with Zerex G03,
New upper/lower radiator hoses and thermostat housing unit.
- Fabricated/installed rear muffler tailpipe hanger
- Installed Meyle rear shocks
** yet to do power steering flush
[/quote]
- Cleaned MAF
- New cabin filter
[/quote]
