Wrong spark plugs?
Teeka56
Year and Model: 2009 C30 T5
Post by Teeka56 »
Removed spark plugs from 2006 B5244T motor. Length of thread is 19mm, replacement plugs are 26mm length??? Which is corrrect???
T5 model.
Checked numerous auto parts sites, most show/list a 26mm reach plug....
Thanks
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
I don't know the length but these where the correct plugs for my 05 T5
https://www.fcpeuro.com/products/volvo- ... r-30650379
Has thanked: 1609 times
Been thanked: 4064 times
Eschew the auto parts figment guides for the user manual recommendation
Volvo or Boschplugs only, please
Teeka56
Post by Teeka56 »
Ok, IPD site lists a Bosch FR7MPP10 , which is 26mm reach.
Plugs I removed are FR7DP......19mm reach...
Which is right. Car ran for at least 15,000 miles on the short plugs....
Longer plug may hit piston .....
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Do you know the entire history of your car?
Doing a little research, the B5244T motor was shipped with earlier 2.4l engines. I've got a 2001 V70 T5 with a 2.3l engine that uses the 26 mm spark plugs. Could this be a junkyard engine put in your 2006 S60 T5?
Maybe the earlier 2.4l engines used 19 mm plugs?
Are you sure you have a T5?
Or maybe you have the B5244T5 engine? The B5244T5 uses 26mm plugs referenced above by velorider.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Take a look at the Denso website and look up the correct plugs
http://densoautoparts.com/find-my-part. ... rchResults
For a 2006 S60 2.4
IKH20TT
For a 2006 S60 2.5
It depends if you have a T2 or T4
IKH20TT for B5254T4
IK20TT for B5254T2
Spark Plug IK20TT ( 4702 )
Mfr Label Iridium TT
Aspiration Turbocharged
Resistance 5000
Ground Electrode Tip Design Platinum Twin-Tip
Ground Configuration Twin-Tip
Ground Electrode Core Material Nickel
Center Electrode Core Material Copper
Center Electrode Tip Material Iridium Rhodium Alloy
Gap Size 1.0 mm
Ground Electrode Quantity 1
Hex Size 16.0
Manufacturer Heat Range 20
Seat Type Flat
Reach 19.00 mm
Thread Diameter 14.00 mm
Spark Plug IKH20TT ( 4704 )
Resistance 5000
Gap Size 1.0 mm
Hex Size 16.0
Seat Type Flat
Reach 26.50 mm
Good Luck
Paul
Teeka56
Post by Teeka56 »
I will check the Denso site.
The engine is a B5244T. Turbo, 20v T5
pgill
Post by pgill »
What number is in you VIN position 6 and 7? (YV1 M S ## 2 6 5 2 049843)
http://new.volvocars.com/ownersdocs/200 ... n2006.html
52?
54?
59?
52 = B5254T4 S60/V70 R AWD - Automatic / Manual
54 = B5244T5 S60 T5 FWD - Automatic / Manual
59 = B5254T2 S80/S60/XC90 2.5T FWD/AWD, V70 2.5T FWD, XC70 AWD - Automatic Only
Teeka56
Post by Teeka56 »
I am not by the car currently. But I will check vin. The tag on the hood listed the engine as “B5244T”
But I did try the denso site. It picks a 26mm reach plug for a 2006,S60,T5, automatic- the denso 4704.
Thanks for your help Paul
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Teeka56 wrote: 18 Nov 2019, 07:22 Ok, IPD site lists a Bosch FR7MPP10 , which is 26mm reach.
Per Bosch:
The 2.4L can use FR7MPP10 or FR7NI33.
The 2.5L can use FR7MPP10 or FR7DPP+ .
FR7MPP10 is OEM for both.
Run you VIN number through the Bosch parts finder.
Active
Past
