Vida2015A Racket
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
There are vendors on eBay sell a "2015A" disk for well over $100. Stay away, it not what it appears to be. It is 2014D with some 2016 data added and a little window dressing.
The 2016 data is sloppy, it shows the only engine option for 2016 XC90 as a Inline 5 cylinder, all the engine options for a 2016 XC90 are inline 4 cylinders. Get the drift?
If you want to check it out or play around with the "2015A", you can get it for free, just use the url below. As is, it will only install in windows 7 Pro.
drive.google.com/drive/folders/1vDQJWgjpZnoqswZLTEhmvg6C0ygIykRk
If you want to install it in Window 10 use the install scripts from the 2014D_RePack copy them to the root directoty of the "2015A". Copy 2014D_RePack:\3PP\Products\SqlExpress\SQLServer2008R2SP3-KB2979597-x86-ENU.exe to the same folder on "2015A"
Use the same install process as 2015D_RePack
Active
Past
