Marking "Topic Solved" is functional again. It's the green check next to your post. BTW, please do use this when your question is answered and verified. Thanks!
MVS-Amazon link helps MVS!
upgrade charging system?
Has thanked: 129 times
Been thanked: 364 times
Re: upgrade charging system?
xHeart wrote: Mon Dec 30, 2019 8:52 am You're correct Misha, the reading at battery cable while idling is 13.5-13.6v, so yes, it is higher than the reading at the cig.lighter.
Unless otherwise, ordering this item https://www.fcpeuro.com/products/volvo- ... 70-9456836
This is a low quality, thin gauge, cable. Same if you buy it from Volvo or from aftermarket suppliers. I've put in a couple of these cables but much prefer to build my own with heavier gauge cable where I have the time.
When using this cable I've also run the new cable in parallel with the old cable, since you have to just leave the old one there. It can only help. Yes there is room at the starter for both lugs.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'07 XC70, 170k
'99 Camry V6 :shock: 130k
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 29 times
Been thanked: 55 times
Post by xHeart »
The FEDEx will bring the new battery cable today so I took few more voltage readings while idling and loading with headlights, warning lights, radio, wiper, heater and fan, all cabin lights with door and trunk open, and iPhone charging at the cig. lighter, the reading were:
- Alternator output at B+ post/– housing: 14.02v
- Battery charge rate at the terminals +/–: 13.12v
- Voltage reader device at cig. lighter: 12.9v
Now battery is out and cooling fan removed, I can see the cable routing. The battery cable's other end connects to the starter, and a second cable connects alternator and starter.
What to check at the starter before disconnecting cables?
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
xHeart
Post by xHeart »
erikv11 wrote: Thu Jan 02, 2020 8:55 am This is a low quality, thin gauge, cable. Same if you buy it from Volvo or from aftermarket suppliers. I've put in a couple of these cables but much prefer to build my own with heavier gauge cable where I have the time.
+1
AND not a direct fit battery terminal. The 1" long 1/4 24 screw for connecting 2 red leads is an insert -- crooked thread -- will loosen and fail. Throwing good money after bad.
It is a critical cable therefore stick with Volvo.
You can't buy anything better or different from Volvo, that is the crux of the problem here. Volvo sells the exact same cable!
Building a new cable is the way to go if you want it done well.
'96 855 NA, 145k
'06 S60 R, 167k
'07 XC70, 170k
xHeart
Post by xHeart »
The battery charging is now restored with ECONOMY replacement cable. Old Volvo terminal is designed to fit various wires. I was able to modify and add square port like original.
The replacement cable terminal arm is short, and the ring is hard to fit over battery terminal -- simply pia!
Here is the pix of old terminal:
misha
Has thanked: 67 times
Been thanked: 176 times
Post by misha »
Now get your battery fully re-charged with a charger and check it periodically.
If sulphating process started because it was always undercharged it will never have full capacity like it should...but it will last longer now when charging issues are solved.
The old clamp was soldered with big soldering iron....how did you just transfer the old clamp on new cable?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
Post by xHeart »
misha wrote: Fri Jan 03, 2020 1:23 pm Now get your battery fully re-charged with a charger and check it periodically.
The battery is new, replacement under warranty, so there is no sulphate build up and charge was 12.65v. The idle charge is 13.8-13.9v at the battery terminals under load, i.e headlights, warning lights, radio, wiper, heater and fan, all cabin lights with door and trunk open, and iPhone charging at the cig. lighter.
No, I did not transfer the old original terminal clamp to new cable. However, the new cable is long enough to be cut off at the clamp and put on the original -- original clamp is WAY BETTER! Can the original camp be reconditioned for the new cable -- like the challenge?
misha
Post by misha »
Charging results are excellent!
It can,but you will need a BIG industrial soldering iron to remove the remainings of the old cable from it and to re-solder a new one.
I wouldn't bother with it unless i have that soldering iron.
Clamps are clamps....cables are those which fails.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
Post by xHeart »
New cable is working -- ample battery charge for a cold start after overnight temps dropping in single digits. The trickle charger may loose its job this winter.
Has thanked: 443 times
Been thanked: 1339 times
A solid 10 -amp battery charger in the garage or in your local club inventory is pretty mandatory in the cold climates
Link To Volvo Glossary
