IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
upgrade charging system?
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 18 times
Been thanked: 33 times
United States of America
xHeart
Re: upgrade charging system?
Post by xHeart » Wed Dec 25, 2019 11:02 am
After checking the connectors, the alternator output under load hovers at 13.56v. The voltage drop test with B+ is 0.28, while voltage drop at battery negative (-) terminal is 0.06, both at 1500-2000 rpm.
Alternator charging never goes above 13.60v.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
misha
Year and Model: '97 850 2.5 20v
Has thanked: 49 times
Been thanked: 112 times
Serbia
misha
Post by misha » Wed Dec 25, 2019 12:03 pm
Did you measure directly on alternator or on battery terminals?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
xHeart
Post by xHeart » Wed Dec 25, 2019 12:18 pm
The set up for voltage drop test using multimeter, and then increasing rpm to 1500-2000:
Black probe at negative (-) battery terminal while red probe at the alternator casing, it reads 0.06v.
Red probe at positive (+) battery terminal while black probe at the B+ post at alternator, it reads 0.28v.
misha
Serbia
misha
Post by misha » Wed Dec 25, 2019 3:39 pm
Check output directly on the alternator while engine is idling.
Red probe on b+ on alternator and black on it's housing.
You should get 14-14.2v at idle.
If not...voltage regulator or alternator are faulty.
If you do....b+cable needs to be replaced because the voltage doesn't get to the battery.
Voltage drop needs to be checked after driving the car for at least 30min and without turning the engine off prior to voltage drop testing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
Has thanked: 3 times
Been thanked: 216 times
jimmy57
Post by jimmy57 » Thu Dec 26, 2019 6:26 am
The 120 amp alternator from 960 is also a choice for more charging power.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 272 times
Been thanked: 849 times
Trinidad & Tobago
Post by abscate » Thu Dec 26, 2019 7:30 am
That’s a big drop on the B+
Do you have an IR gauge you can check the temperature of the cable after 15 minutes running with all the lights on ?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
xHeart
xHeart
Post by xHeart » Thu Dec 26, 2019 9:35 am
Cold start and idle reads/hovers 14.08-14.12v with your set up misha. So cable?
misha
Serbia
misha
Post by misha » Thu Dec 26, 2019 12:05 pm
Yep!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
xHeart
Post by xHeart » Thu Dec 26, 2019 12:18 pm
Yep!
Just positive (red cable) or negative cable too?
misha
Serbia
misha
Post by misha » Thu Dec 26, 2019 3:48 pm
Usually the part from positive battery terminal to starter is the one which fails.
In your case you should replace the negative too.
Replacement MUST be the same thickness as original or slightly thicker...but DO NOT replace it with thinner cable.
25mm2 is EU spec....i guess that this is equal with 2awg(U.S)but check the conversion table.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
