Trivial - Air filter brand you trust for performance?
gcha8e
Year and Model: 2005 S60 2.5T AWD
Has thanked: 20 times
Been thanked: 2 times
Post by gcha8e »
The essential (trivial) question is what air filter brands do you trust for high performance? My car is getting old and I need to give it love to keep the edge on the road :D
So in shopping for an HB3 replacement bulb which Walmart had at $8 for 2 (+1 happiness). So then I also looked at their air filters, only to discover for the first time that there are 4 different engine base versions of the 2.5T AWD listed. The volvo forums VIN decoder says I have the 153 CID.
For that engine base, the only air filter compatible on Walmart's site was the K&N 33-2176 High Performance - at $62.99. :shock: I was intrigued by that and would prefer a "high performance" option for less than $30.
Rattnalle
Year and Model: 2004 V70 2.5T
Been thanked: 133 times
Post by Rattnalle »
Any regular paper filter the right size really. I mean it's not exactly rocket science.. A standard filter is $10 or so over here.
Has thanked: 1609 times
Been thanked: 4065 times
you can sell headlights at 100% margin when you sell air filters at 5000% margin
Use a Mann or Volvo filter, buy once , pay once if you are a cheapskate like me. You won’t get HP increases from air filter changes
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
The last place you'd ever want to look for anything for a Volvo (or any other higher end vehicle) is a Walmart.
Unless things have changed a whole lot recently, cartridge oil filters and low {sales} volume air filters are essentially "special orders" to shops even like AutoZone.
You're much better off going straight to FCPEuroparts or eEuroparts.com or even IPDUSA.com. Their competent service is waiting for you. They have frequent sales too.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Abscate is giving good advice. My S80 has almost exclusively used Genuine Volvo filters. Twice I installed aftermarket units, but had them changed again at the next service. The MAF sensor was never cleaned but was replaced a few months ago for the first time. That's nearly 16 years and 187K. Also to date the throttle body is factory and was cleaned once around 150K which was not the problem. 192K on the clock now and she is running perfectly. Also both turbos and the intercooler are factory. I would think those items are relying on the air filter to keep them clean which the Genuine Volvo filters have done. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
B5254T2 OE filter is Mahle. Same for cabin filter.
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
Boils down to Mahle OE or MANN. Whatever's cheaper at the time.
Georgeandkira
Good advice chris11211 (Brooklyn?) but the OP needs more.
He has to be broken of the "Shopping for Volvo and Rolls Royce parts at the local Walmart" habit.
June
Post by June »
I forgot to mention that the first time I had to replace the air filter the correct 04 S80 T6 filter the parts store called for was a special order. So I took the one out of the car in the parking lot and found one the same size by opening similar sized boxes until one was the same. The funny part is it was 1/3 the price of the correct one their computer listed. Like $10.99 vs $28.99. June
My Volvo cars owned
1996 960 ordered
cleven
Year and Model: 2001 V70 T5
Has thanked: 1 time
Been thanked: 5 times
Post by cleven »
Georgeandkira wrote: 26 Nov 2019, 11:48 The last place you'd ever want to look for anything for a Volvo (or any other higher end vehicle) is a Walmart.
Naaa walmart fluids and such are way cheaper. Why spend more when you can get the same stuff cheaper at walmart?
