V70 pulling to the left
2001 - 2007 XC-70
V850B5254T
Year and Model: 2007 V70T aut
Post by V850B5254T »
Hi everybody,
My 2007 V70T aut. 282.000km (~175.000 miles) pulls to the left more often than not.
An example:
At a flat straight road, I remove my hands from the steering wheel.
The steering wheel turns ~3° to the left and the car follows.
I have changed this:
- Top bearing in McPherson
- Springs
- Dampers
- Whishbones
- The fluid in the power steering fluid reservoir, the old fluid was brownish
and have had a full 4 wheel alignment done at a workshop.
Further: now and then I hear a distant 'klonk' noise from the front. It not loud and is as much felt as heard.
I have tried to provoke the noise to appear without much luck.
It appears usually when driving straight after a turn, acceleration or braking.
I have heard it once when leaving my driveway at very low speed, with the steering wheel full left and over the small ramp onto the street.
Is there anyone in this forum who can provide good advice for solving this problem?
Regards from Denmark
oakey
Now:
Volvo V70T2 2007
Volvo S60T2 2005
Before:
Volvo 850T stc. 1996
Volvo 940T stc. 1998
Volvo 850 stc. 1994
Volvo 240 stc. 1988
Volvo 240 van. 1981
Ford Granada Van 1973
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 37 times
Been thanked: 82 times
Re: V70 pulling to the left
Post by MoVolvos »
The alignment on my S80 is correct and drives straight but a little acceleration will pull it the left and will settle back again.
It cheap and most older cars will need it anyways.
Poly Front Subframe Bushing Insert Kit or Similar Kit from Parts Sweden
https://www.ipdusa.com/products/8969/12 ... 68-3507923
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Georgeandkira
Year and Model: 2007 V70 base
Has thanked: 25 times
Been thanked: 54 times
Post by Georgeandkira »
You must admit ~3º isn't much.
How long ago did you change your "wishbones" (aka Front Control Arms)?
If they came with rubber bushings which, a) have aged or b) were cheap to begin with, poly bushings will help.
I never quantified any wandering or torque steer in my 2002 but I do know the poly bushings gave me a great, solid feel.
As MoVolvos said, give the subframe poly bushing upgrade a shot. You might do it first as it is so easy to do.
I put those very ones in my '07 and felt an improvement.
The improvement was not as large as that from the poly control arm bushings but still very real.
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 75 times
Post by vtl »
Check your rear subframe bushings, especially the front large one, to which the stay is connected. The car may be aligned properly, but when it gets to the road the worn bushing slacks and changes the toe angle of the tire.
Also does your car have Nivomats? The Nivomats have to be pumped up before the alignment is performed.
05 XC70 265k, 16 XC60 45k, 19 Tundra 5k
V850B5254T
Georgeandkira wrote: Mon Nov 25, 2019 8:21 am You must admit ~3º isn't much.
__________
Hi,
Thanks for your reply.
About angle:
Maybe the angle is 5º or 7º, - I cant measure it while I' driving :D
When the problem is present, I have to keep a firm hand on the wheel to make the car drive straight.
About parts change:
All parts mentioned have been changed in connection with the problem, - within the last month.
Regards
oakey
Now:
Volvo V70T2 2007
Volvo S60T2 2005
Before:
Volvo 850 stc. 1994
Volvo 240 stc. 1988
Volvo 240 van. 1981
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
V850B5254T
vtl wrote: Mon Nov 25, 2019 2:16 pm Check your rear subframe bushings, especially the front large one, to which the stay is connected. The car may be aligned properly, but when it gets to the road the worn bushing slacks and changes the toe angle of the tire.
_______
Hi, thanks for your reply.
About rear subframe:
I have considered, but ruled it out as it is the steering wheel that rotates to the left when I leave it alone.
I will look into it again.
______
About Nivomat:
The original Volvo Nivomat I have installed in the car can not be pumped up.
It is a shock absorber with 'all included' together with softer springs.
The shock absorber has some kind of internal pump that levels out the ride height when driving and when loaded.
No load = no action.
As I understand, the geometry of the rear suspension does not change much from unloaded to loaded.
Anyway, - that is my understanding.
My thank to you
oakey
Now:
Volvo V70T2 2007
Volvo S60T2 2005
Before:
Volvo 850 stc. 1994
Volvo 240 stc. 1988
Volvo 240 van. 1981
Renault 4L 1969
VW T2 1970
Morris Mascot 1970
Renault 4L 1962
diyrwolf
Year and Model: 2001 v70 XC
Post by diyrwolf »
V850B5254T wrote: Mon Nov 25, 2019 12:49 am Hi everybody,
An example:
- Springs
- Dampers
- Whishbones
oakey
Did you ever make any progress with this situation? I just purchased an 01 v70 XC and have some pulling/torque steer type issues. Trying to prioritize my troubleshooting list.
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 297 times
Post by oragex »
If you guys happen to be parking or just driving on steep inclines, the subframe bushings get soft after 130K miles and can cause a steering pull. Of course, there could be other reasons such as low pressure tire or dragging caliper
- Pete -
Has thanked: 62 times
Been thanked: 114 times
Post by - Pete - »
I didn't use my fine tooth comb, but I never saw mention of ball joints or tie rod ends in there. I'd assume if both control arms were replaced new ball joints were done at the same time, but I didn't see it written down. Those would be high on my list of potential culprits. Tire psi first.
Also, if the car is behaving in FWD only, this could account for some torque steer, but I wouldn't think it would be a constant pull. Rain grooves in the road can make you erroneously wonder about alignment/tire psi.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
