While replacing the timing belt on my '02 V70 XC my initial pre-removal inspection of the belt showed the exhaust cam was off by more than one notch clockwise. The intake cam and the crankshaft alignment were spot-on and the car has been running fine for a long time. A worn or stretched belt seems like it would have caused the cam to move off alignment in a counter clockwise direction.
Is there a common cause that would induce camshaft misalignment without generating any codes or performance issues? Should I rotate the exhaust cam so everything lines up better when the new belt is installed?
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
Misaligned Camshaft Timing Mark
- XCMat
- Year and Model: V70XC 2002
- Has thanked: 2 times
- Been thanked: 0
- oragex
- Year and Model: S60 2003
- Has thanked: 91 times
- Been thanked: 213 times
Re: Misaligned Camshaft Timing Mark
Don't think a belt would 'stretch' at least not an eye-measurable amount. If only the exhaust cam is misaligned, I would guess the person who replaced the belt had the ex cam move off mark. Also careful with the mark on the crank pulley and block - crank has two teeth marked, block has a hard to see bump - the bump will stay between the two teeth, more towards the front one
- XCMat
- Been thanked: 0
Thanks Oragex. Here's a shot of the crankshaft. The alignment is definitely biased towards the front groove, just as you said. I'll tweak the exhaust cam a little counter clockwise and call it good!
- oragex
I think I was wrong about the crank mark on the block, would rather be closer to the rear tooth with notch. Notice the bump 'mark' is sitting at the left lower 'corner' of that U shaped piece of metal on the block - at least on my car. I could feel it by touching. Given the camera angle, it looks pretty much like on your car
A better picture of the block mark for the crank pulley - blue line
- Has thanked: 0
- Been thanked: 113 times
The CRANK marks, this is exactly how they should line up...
- oragex
Great pic
- XCMat
- Been thanked: 0
That's the money shot right there... I'll have to take a closer look again now that I have the belt off. Thanks!
Driver's window misaligned
by zsam » Fri Jan 01, 2016 3:50 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 1 Replies
- 358 Views
Last post by cn90
Fri Jan 01, 2016 4:30 pm
sunroof cassette misaligned
by nthnnxn » Tue Jan 12, 2016 9:11 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 0 Replies
- 457 Views
Last post by nthnnxn
Rear Shocks. Can't access upper mount bolts. Misaligned
by Tarquin » Mon Dec 02, 2019 6:08 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 4 Replies
- 75 Views
Last post by Tarquin
Tue Dec 03, 2019 9:53 am
Which is the timing mark
by stephansvolvo » Tue Mar 28, 2017 4:54 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 5 Replies
- 1294 Views
Wed Mar 29, 2017 10:40 am
