Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Steering rack Leak AWD Compatibility
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 9 times
Post by befarrer »
My steering rack is leaking out of the steering shaft. The car is a 98 V70 AWD, and finding a used rack will be near impossible. Looking online, it looks like 98-99 AWD racks are the same. I'm planning on rebuilding mine in the spring, but wondering if a leaking rack is common, and something a rebuild kit wont fix?
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Has thanked: 597 times
Been thanked: 1693 times
Welcome, befarrer.
There are two flavors of rack on these cars, one made by TRW and one by SMI, you have to roll under and see which one you have.
Here are some relevant threads. Short version m if you replace everything from rack to tie rod ends you can use either one. If you want to use your existing tie rod ends , you have to match what you have.
Hang ups on this job.
1 power steering line fittings on rack often nasty
2 steering coupler pinch bolt often nasty, good trick is to release coupler inside car Andre drop through boot
3 it’s a game off Tetris to get rack out through wheel well
4 you need to jack engine and subframe a bit to clear bolts , reported in thread below
viewtopic.php?f=1&t=88812&p=500414&hili ... rw#p500414
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
befarrer
Has thanked: 1 time
Post by befarrer »
The rack doesn't look too bad to get out, I changed one on a Focus a few months ago, was a similar ordeal. I originally thought it was my power steering fitting o-rings on the rack, I changed them out about a month ago, I think it slowed down, the return line seal was damaged and the fitting was loose. I'm hoping to throw a rebuild kit in this rack, replace all 4 tie rod ends while its apart too. When I first started driving this car, it had the occasional hard spot, but since I have been driving it and replacing the leaked out fluid with Lucas stop leak, the hard spots have disappeared, but my car sat awhile so I assume the seals are all hard.
98 V70 GLT AWD
05 VW Golf TDI
Has thanked: 64 times
Been thanked: 445 times
On an AWD you have to drop the front subframe at the rear and loosen the front subframe bolts to remove it. Otherwise the steering rack cannot be moved as it fouls on the AWD system at the front.
The re-build kits can be hard to track down and none had the top dust seal. I bought a set of seals from a company in the US (Corteco?) and they could not supply that particular seal and otherwise it is NA (this was for an SMI rack).
2006 XC70
RickHaleParker
Been thanked: 808 times
Post by RickHaleParker »
Some people have had good luck ATP AT-205 Re-Seal on a leaking rack. Worth a try, might buy you some time.
