2001 C70 rear mirror replacement
Nigel
- Year and Model: 2001 C70 Convertible
- Has thanked: 3 times
Hello all, has anyone done a rear mirror replace on a 2001 C70? I've unscrewed the 4 overhead panel hex screws, but it is still clipped in, by wires and the lights which are attached to the entire panel. Are these lights able to be popped out? Does anyone have advice for the best method to remove this panel so I can get to the mounting screws for the mirror itself
redc70
- Year and Model: 1999 c70 convertible
- Has thanked: 9 times
- Been thanked: 5 times
Hi, I don't know if the cabrio is different, but I've had mine out several times to fix cracks and splits. Take out the four hex head bolts that hold the sun visors in. Drop them down enough to unplug the vanity lights and set the sun visors aside. If you then drop the panel enough you can unplug the switches for the interior lights on either side of the rear view mirror. The panel comes out pretty easy, but I would advise 2 people as once it is loose it is really flimsy. In short, yes all the lights can be unplugged and the panel should come out easy. Again, mine is a '99 C70 convertible so yours could be different. Mine was in such bad shape with cracks and not repairable that I had to buy one of different color off ebay, paint it and install. That was 2 years ago and needs to come out again to fix cracks ...again. Vet poor quality I think.
When you put it back in, don't tighten the four hex screw too much as they can crack the panel.
Hope this helps and good luck!
redc70
Mine came out from the car, ie popped out of their rectangle slots, and I also unclipped the little harnesses from the car. So, I had the lights, completely separated from both that panel and the car itself. It is somewhat difficult to get them back in flush with the panel on reinstall.
If I remember right, wiring clips from both vanity lights hook into the main light array next to the rear view mirror. No idea how the mirror is held in place.
- 1645 Views
Last post by phils94850
- 1692 Views
Last post by 850_GLT_Owner
- 1167 Views
- 6116 Views
Last post by azureblue
- 1242 Views
Last post by senornose
