Crank no start continued
2001 - 2007 XC-70
Wardhill
Year and Model: 2001v70 xc
Post by Wardhill »
Ive been dealing with a crank no start on a 2001 xc . Noticed a lot of oil on top of the block under decorative cap. Ive heard oil cap is prone to leaking. Thought I’d check my coils and plugs . When pulled plugs in cyliders 2 and3 were drenched in oil beyond threads iinto cyliders it seemed. Pulled all plugs waited over night for excess oil to drain down . I replace all plugs and still crank no start. Can someone help me
Thanks
Jeff
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 75 times
Re: Crank no start continued
Post by vtl »
Any dashboard needles jumping while cranking?
Did you check fuel pressure?
05 XC70 265k, 16 XC60 45k, 19 Tundra 5k
tyguyc
Year and Model: 2004 xc70
Post by tyguyc »
Is your gas tank less than half full? I read on here that the early 70 had a check valve in the tank and it would fail leaving the fuel pump to only pump the top half of the tank. probably not it but easy to check, as it the fuel pressure at the rail. You can use a gauge from a tool store or just see if the rail has pressure by pushing on the valve (think tire valve) and see if it squirts out. have some rags at hand.
Wardhill
Post by Wardhill »
Okay I need to check the fuel pressure I sprayed starting fluid into the air intake and it started up for a few seconds leading me to believe it it’s either the fuel pump or if your pump relay can anybody tell me where that really is located on this model I can’t seem to find it through a search
Has thanked: 379 times
Been thanked: 1185 times
Well done.
No fuel pump relay on a 2001, the failure point is a pump electronic module called the PEM
The diagnostic is to rent a fuel pressure gauge from autozone and measure the required 52 psi at the fuel rail
Link To Volvo Glossary
Wardhill
Post by Wardhill »
Ok I don’t get any fuel pressure at rail. I can hear a three second hum of fuel pump with ignition on . Does this point to the pem? I would think I’d get something if the filter were clogged. My no start happened suddenly without symptoms
