P80 Fuel tank drop in 30 minutes V70 FWD NA 1998
Has thanked: 376 times
Been thanked: 1176 times
Volvo Repair Database P80 Fuel tank drop in 30 minutes V70 FWD NA 1998
Pictures to be added, from the 1998 parts car, Clarke
I jacked the car up on left side and got about 1 foot clearance under rear, wheels on
I had previously drained tank to about 1 liter of fuel left.
Removed 5 M6 screws and removed Al plate over pump
Disconnect all electrical connectors going through plate and feed through
Levered off two slide fittings, then pop off two fuel lines.
(Note - if you are sensitive to fuel smell, do this last.)
Open fuel hatch - dig out the large (150mm radius) snap ring in the rubber grommet and free the grommet from the fill neck
Position jack under tank (not needed if empty)
Remove two M8 (14mm hex_ bolts from rear of each strap, tank drops
Release clip 'organizer holding fuel and vapor lines
Remove clamp of vapor line heading forward and remove line (pliers work here, VW style clamp)
Pull tank and fill pipe back as unit.
Elapsed time 30 minutes not including draining. I drained by applying 12 Volts to the pump (red/black wires) T2 connector and running front fuel line into a gas can
Link To Volvo Glossary
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Re: P80 Fuel tank drop in 30 minutes
Post by ZionXIX »
How fast is the fuel pump?
markone
Year and Model: 1997 850
Has thanked: 17 times
Been thanked: 7 times
Post by markone »
Wow. Maybe you should get on a pit crew? Thanks for sharing.
Would this work on a 98 XC AWD? If so, would this be a good start in a way to replace the fuel sending unit, as opposed to cutting a hole in the floor for access to same??
1997 850 Sedan NA, manual trans, 268k miles
1998 V70XC AWD, turbo/auto 165k miles
1998 V70, NA/manual trans, 351k miles
2005 BMW X3 3.0i, auto, 135k miles
2010 Toyota Highlander AWD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 330 hours
markone wrote: Wed Nov 27, 2019 1:10 pm Wow. Maybe you should get on a pit crew? Thanks for sharing.
No, sorry. This is a major McGilla Gorilla project on an XC due to theRWD and shaft
The above is for a FWD Base V70
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 33 times
Been thanked: 42 times
Re: P80 Fuel tank drop in 30 minutes V70 FWD NA 1998
Post by ecbsykes »
*cries in AWD*
2000 V70XC - 300,000 miles as of 11 Aug 2020
ZionXIX wrote: Wed Nov 27, 2019 12:03 pm How fast is the fuel pump?
I was using a battery charger to deliver about 6 amps to the pump, and I filled a 5 gallon gas can in about 10 minutes, or 2 liters per minute flow
wizechatmgr
Has thanked: 24 times
Been thanked: 63 times
Post by wizechatmgr »
abscate wrote: Wed Nov 27, 2019 7:29 pm
Sounds about as quick as an XC can go through gas if one stomps on the gas pedal =P
1999 V70 XC AWD - ~193k miles
I’m not sure new fuel tanks are available but replacement fuel tanks have a issue with a new style rollover, or June Valve, that need to be understood
Bulletin attached
Has thanked: 110 times
Been thanked: 325 times
Junkyard seems a better source if you ever by chance came across a fuel tank that needs replacing.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
erikv11 wrote: Fri Nov 29, 2019 9:21 am Junkyard seems a better source if you ever by chance came across a fuel tank that needs replacing.
Even better if buy mine, delivered anywhere in the Northeast except CT. Iowa too.
:D
Only problem with the junkyard route is I hate going under cars on unknown turf.
