If I had a donor car...
imac
Year and Model: 1999 S80 T6
Post by imac »
I'm having a helluva time diagnosing electrical issues in 99 s80 t6,
Hypothetically, if I had a donor car, what modules are vin specific and need to stay as a set?
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Every single CAN node basically.
So everything that ends in EM or CM. CEM, TCM, ECM etc etc.
imac
Post by imac »
Ok so the
CEM
TCM
ECM
REM
UEM
SRS
Are vin locked,
But not
ABS
ETM
AUM
PDM
DDM
PSM
CCM
Is this correct? Could my key be programmed to work with the immobilizer, or am I swapping ignition module as well?
This may be my easiest option, believe it or not
Thanks
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
What reason you want to swap all modules?
imac
Post by imac »
yagger
Post by yagger »
Did you try disconnect modules one by one from CAN bus?
imac
Post by imac »
Yes, i have. But can something like a DDM take down the high speed network that ECM works on?
yagger
Post by yagger »
Through side ways only, like a power for example.
imac
Post by imac »
I found a 2005 s80 t6, mine is a 99. Does anybody know, electrically, what is different between a 99 and an 05? :)
yagger
Post by yagger »
It are very different cars.
