IPD sale XeMODeX - Experts in Volvo Electronics Volvo modules repair and programming
Please use the MVS Amazon link when you buy anything at all! It helps this site. Thanks very much!
Get email notification of topic replies. Log in or register (free). Amazon Link Buy anything with this and it helps MVS!
850: Split rivits, fender liners, mud flaps and rocker panels
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 58 times
Been thanked: 37 times
Re: 850: Split rivits, fender liners, mud flaps and rocker panels
Post by Cookeh »
I mean a nutsert. They often get called different things, like rivnut or blind rivet nut. You install the nutsert in the exact same way as a normal rivet, and come in sizes from M2 to M10, so finding one to suit your hole size is easy. This goes into the bumper or fender etc. You then thread a bolt (button head preferable) into it, and the liner or mudguard is held by the head of the bolt.
Year and Model: 850, S/V70, 06 S60R
Has thanked: 117 times
Been thanked: 333 times
Post by erikv11 »
Cookeh wrote: Sun Dec 01, 2019 5:57 am I mean a nutsert. They often get called different things, like rivnut or blind rivet nut. You install the nutsert in the exact same way as a normal rivet, and come in sizes from M2 to M10, so finding one to suit your hole size is easy. This goes into the bumper or fender etc. You then thread a bolt (button head preferable) into it, and the liner or mudguard is held by the head of the bolt.
Sounds like a good idea. How does this deal with there being a smaller hole in front (e.g. muflap) and larger hole in rear (e.g. body panel), or do you also need to drill out the various pieces so they all have the same diameter hole?
Please post links or pictures so we know what you are talking about, looks like there are several different kinds of nutserts.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 145k
'98 S70 NA, 220k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 293k
'06 S60 R, 167k
'99 Camry V6 :shock: 130k
gone: '96 NA 850 210k, '98 NA V70 182k
ZionXIX
Has thanked: 9 times
Been thanked: 46 times
Post by ZionXIX »
Those nutserts looks perfect. I'm definitely going to try those instead of buying the rivets. So tired of having to drill those out to replace the fender.
Post by erikv11 »
ZionXIX wrote: Sun Dec 01, 2019 8:50 pm Those nutserts looks perfect. I'm definitely going to try those instead of buying the rivets. So tired of having to drill those out to replace the fender.
Link and/or pic? Will you need to drill out the aligned holes to be connected, so they are all roughly the same diameter? Thanks!
'96 855 NA, 145k
'06 S60 R, 167k
Cookeh
Post by Cookeh »
erikv11 wrote: Sun Dec 01, 2019 10:14 am
Not sure I follow what you mean by different sizes. The mudguards/bumpers/archliners all have one size, so would require one size of rivnut for all 20-odd of them front and rear. The sill covers are a different size so would require a different sized rivnut, but I am not aware of any instances of the rivets changing within a component group?
Unless you mean the hole in the bumper being different in size to the arch liner? In which case that difference is size is irrelevant as the rivnut only goes into one of those pieces. So if you were doing an arch liner, the rivnut goes into bumper, then the liner is held in place by the bolt threaded into the rivnut. So the only hole size that matters is the one you're putting the rivnut into.
You choose your rivnut based on the size of the hole you have to fill, for example the arch liner and mudguards have a 5mm hole, so you buy a rivnut that fills a 5mm hole. As an example of rivnuts, the link below contains steel, stainless, aluminium and rubber coated rivnuts. The description details what size hole each nut is suitable for, so for the arch liner case above you'd need an M3 rivnut. Different rivnuts from different suppliers will differ due to the thickness of the walls etc, so please do check with your supplier.
https://rover.ebay.com/rover/0/0/0?mpre ... 3569114123
You then need a button headed bolt to thread into the fastened rivnut. M3 rivnut would obviously require an M3 bolt.
ZionXIX
Post by ZionXIX »
Post by erikv11 »
Cookeh wrote: Mon Dec 02, 2019 7:06 am ...
Yes, for the front mudflap you have three different holes: (1) the mudflap in front, (2) the wheel liner in the middle, and (3) the rocker panel in the back with a blind hole. Now I get it, just to reiterate what you said the way it works is:
(a) Pick a rivnut size that fits pretty much exactly the hole in the back piece. So e.g. the rocker panel hole for front lower mudflap attachments.
(b) Use a rivnut install tool or fashion a simple jig with a bolt that fits the rivnut thread, to install the rivnut. The rivnut collapses the way a rivet does, to crimp in tight into the back piece.
(c) Use a screw diameter that fits through all the other holes between the front piece and the back piece, with a screw head wider than the hole in the front piece. So e.g. wider than the hole in the front mudflap.
Thanks!
'96 855 NA, 145k
'06 S60 R, 167k
JimBee
Has thanked: 13 times
Been thanked: 28 times
Post by JimBee »
OR you can pick through NAPA's impressive fastener kit and find a hefty self-threading screw with a broad flat head that's a tight fit for the largest hole, grind it in there and be done. That's what I did on one of my 93 mud flaps that was coming loose. After maybe 5 years it's still holding well.
Cookeh
Post by Cookeh »
erikv11 wrote: Mon Dec 02, 2019 9:05 am
Thanks!
That's exactly it, and much better explained than I managed myself! I much prefer it to using the blind rivets, as aside from being significantly cheaper, it's much easier and time-efficient to simply unscrew a bolt than it is to drill a rivet out.
FLXC90
Year and Model: 98 V70 T5
Been thanked: 35 times
Post by FLXC90 »
Cookeh wrote: Sat Nov 30, 2019 10:07 am M4 aluminium rivnuts and button head bolts... Never worry about finding suitable rivets again, or paying a fortune for them everytime.
and what type aircraft do you work on?
Current Volvos:
