Head Removal s70 glt
Mstrshkbrnnn
- Year and Model: 94 850
- Been thanked: 2 times
I'm in the process of removing the head on an s70 glt, and I've removed all necessary bolts (to my knowledge), but the head is being stubborn and doesn't want to come off. All intake and exhaust manifold bolts have been removed. intake manifold has been removed. stabilizer mount bolts have been removed. cam cover and head bolts have been removed. Am I missing any? or do I just have to muscle it off? I feel as though it shouldn't be this stuck on there.
'94 854 NA 287k (bought for $400)
'98 s70 GLT 243k (bought for $250 currently non running)
'96 854R 173K (bought for $900)
'88 245 DL who knows (bought for $600)
- Has thanked: 312 times
- Been thanked: 818 times
They get pretty stuck, you have to kind of force it loose Use the aluminum tabs built into the head and block, to get them separated. But be careful about mating surfaces and to not damage the aluminum. Once you break loose the head gasket you can lift it out.
Also did you get the water pipe bolts on the back, near the timing belt?
Mstrshkbrnnn
are you referring to the coolant pipe going to the turbo? if so, that line isn't connected to the head at all. If not, maybe I missed one. could you send a reference pic?erikv11 wrote: 29 Nov 2019, 18:46 Also did you get the water pipe bolts on the back, near the timing belt?
No it's a bit lower than the turbo coolant line - this coolant pipe is there on both NA and turbo models, since they use the same casting, of course.
Two 10 mm bolts, they screw right into the head, see the post by jdchillin and gasket #15 on the parts diagram on this thread: viewtopic.php?t=73186
- 11 Replies
- 1898 Views
Last post by stephansvolvo
- 13 Replies
- 8516 Views
Last post by lifeofgold
- 16 Replies
- 2109 Views
Last post by erikv11
- 554 Views
Last post by dikidera
- 2442 Views
Last post by jmorman
