Did you know? 🤔
Head Removal s70 glt
Mstrshkbrnnn
Year and Model: 94 850
Has thanked: 3 times
United States of America
Mstrshkbrnnn
Post by Mstrshkbrnnn » Fri Nov 29, 2019 6:31 pm
I'm in the process of removing the head on an s70 glt, and I've removed all necessary bolts (to my knowledge), but the head is being stubborn and doesn't want to come off. All intake and exhaust manifold bolts have been removed. intake manifold has been removed. stabilizer mount bolts have been removed. cam cover and head bolts have been removed. Am I missing any? or do I just have to muscle it off? I feel as though it shouldn't be this stuck on there.
'94 854 NA 287k (bought for $400)
'98 s70 GLT 243k (bought for $250 currently non running)
'96 854R 173K (bought for $900)
'88 245 DL who knows (bought for $600)
Has thanked: 81 times
Been thanked: 245 times
Re: Head Removal s70 glt
Post by erikv11 » Fri Nov 29, 2019 6:46 pm
They get pretty stuck, you have to kind of force it loose Use the aluminum tabs built into the head and block, to get them separated. But be careful about mating surfaces and to not damage the aluminum. Once you break loose the head gasket you can lift it out.
Also did you get the water pipe bolts on the back, near the timing belt?
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
Mstrshkbrnnn
Mstrshkbrnnn
Post by Mstrshkbrnnn » Fri Nov 29, 2019 8:11 pm
are you referring to the coolant pipe going to the turbo? if so, that line isn't connected to the head at all. If not, maybe I missed one. could you send a reference pic?
Post by erikv11 » Fri Nov 29, 2019 9:42 pm
No it's a bit lower than the turbo coolant line - this coolant pipe is there on both NA and turbo models, since they use the same casting, of course.
Two 10 mm bolts, they screw right into the head, see the post by jdchillin and gasket #15 on the parts diagram on this thread: viewtopic.php?t=73186
'96 855 NA, 145k
'06 S60 R, 165k
