Hello, I have a question about the compatibility of the 2.5t and the 2.4t engines. I had an 02 Volvo S60 2.4t and I have done several modifications to it. New coil packs, new alternator, larger turbo & intake ect ect. I recently totaled it in the rain. The power train is still in excellent condition, but the body is in too bad of condition to repair on my budget.
I have found an 05 Volvo S60 2.5t AWD with a blown engine. The transmission is in good condition too. My question is will I be able to do an engine swap with these two vehicles? I really loved my Volvo, I also have wanted the AWD version. I have invested quite a bit into my wrecked Volvo and plan on removing and adding parts of my suspension to the 05 as well. Will I be able to do all of this?
2005 Volvo S60 engine swap
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
There are a ton different parts from an 05 than what's in 02 that would make the computer go nuts (for example, the throttle body), a change which started in 05, so you're really looking at an 01-04 S60. Then you would need to figure out the issue with the computers to make sure they're compatible.
In my opinion, you are messing with 2 f***ed up cars, past their prime, and damaged to the point where it seems like a good idea to just junk the thing and get something that's in one piece. If a swap comes out to a grand, then fine, otherwise if you really like Volvo so much then just lookout for the 07 V70 or an 09 S60. A lot of issues should be ironed out at that point, and would actually be worth the 5 grad or whatever so you can enjoy it for a lot longer.
Again, I ain't a pro, just my opinion. More qualified people should fill you in; hell, ask your local independent Volvo mech for help.
ibwayne
- Year and Model: 2002 s60 2.4t
- Has thanked: 1 time
Oh no, I was hoping for a better outcome. I’ve invested quite a bit in the motor and suspension. Don’t really want to junk it. Was hoping to put it in something. I’ve had the car for a few years, and have gradually gotten it where I wanted it. It’s been a great car, good sleeper esp with the upgraded turbo, intake, suspension, ect. I hope there is more advice out there. But, thanks for your input though. Have a great day.
- 2097 Views
Last post by cdretc
- 1987 Views
Last post by darylrobert
- 1407 Views
Last post by allehagelnjuif
- 14 Replies
- 4452 Views
Last post by ggleavitt
- 17 Replies
- 6383 Views
Last post by henrysin44
