Issue * came across harvesting a MAf today
The MAf on NA cars are made by DENSO and mount with two M6 (10mm head ) bolts
The bolts are typical steel but bolt into brass threads fused into the air cleaner
I had bad galvanic corrosion on one of mine, so bad the fused and broke the threaded insert ou to the plastic
I had to Dremel it put and re-epoxy the insert into the MAF
Check your cat too, while you test your bolts.
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
P80 NA DENSO MAF mount bolts issue 1275636
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 234 times
- Been thanked: 768 times
Link To Volvo Glossary
- Year and Model: 850, S/V70, 06 S60R
- Has thanked: 72 times
- Been thanked: 228 times
Re: P80 NA DENSO MAF mount bolts issue 1275636
Denso is 99+ cars only. 98 and prior are Bosch, different part.
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
'96 855 NA, 140k
'06 S60 R, 160k
- wizechatmgr
- Has thanked: 22 times
- Been thanked: 53 times
Your cats appear to be bad, both are missing their precious metals =P
1999 V70 XC AWD - ~183k miles
- Been thanked: 18 times
The cats also look dark - may need cleaning. Might be too rich condition.
(why you always want to logon and see the details and not just the text)
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
I see you got each cat to face the tail pipe, but now they flow in opposite directions???!!!
'96 855 NA, 140k
'06 S60 R, 160k
'96 855 NA, 140k
'06 S60 R, 160k
Clarifying a bit more
The design is m6 bolt, clearance. Brass boss on air cleaner housing, threaded brass m6 insert in MAF, two pieces.
Look how the bolt corroded in the brass boss, but not in the insert.
Strange. When I went to unscrew this it locked up in both, then broke the insert out of the MAF. It was also locked into the brass boss.
Starting issue (Bad aftermarket MAF) new Bosch MAF worked
by ChadLee » Mon Aug 08, 2016 11:51 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 26 Replies
- 3232 Views
Last post by ChadLee
Wed Aug 17, 2016 5:52 am
Are Bosch and Denso ECUs interchangeable?
by drjurman » Sat Sep 17, 2016 2:17 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 325 Views
Last post by vtl
Sat Sep 17, 2016 7:39 pm
2004 XC70 -- Spark Plugs; Denso Iridiums?
by E Showell » Tue Jan 01, 2019 11:23 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 14 Replies
- 401 Views
Last post by mrbrian200
Wed Jan 02, 2019 10:32 pm
P80 lower timing belt cover bolts 974674
by johnhb » Sun Mar 05, 2017 1:04 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 20 Replies
- 1321 Views
Mon Mar 06, 2017 9:51 am
