Im contemplating replacing my timing belt. Several shops and dealer are quoting $900-1500 for parts and labor. I have done several timing belts on a 1995 850 and a 2006 S60 T5, neither car was very difficult. Anything different or more difficult with the 2012 S60 T5 as I have not been able to find much information online and the Chiltons DIY is virtually useless also. Looks like the motor mount on the passenger side is different and will require the engine to be supported on that side.
In the 850, I replaced the water pump only once and in the previous S60 I never did. I drove the two cars for a combined 600,000 miles. Any comments on the water pump longevity on the newer Volvo engines?
Thanks in advance.
2012 T5 S60 Timing Belt replacement
Fourthvolvo1
- Year and Model: 2012 S60 T5
Thanks,
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
Fourthvolvo1
The 2006 S60 was a 2.5 T not T5.
Thanks,
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
Fourthvolvo1
Completed timing belt replacement. Not much different than the previous 4 belt replacements. Due to the problems I experienced in the previous timing belt replacement on an older S60, with the exhaust camshaft moving so readily, I purchased a cam-lock tool which was very helpful. Also on the 2012 S60 its very difficult to get a straight line of sight for alignment between the rear camshaft timing mark and the cover. What I found very helpful was someone mentioned on another forum that there are 18 teeth on the belt between the two camshaft timing marks. This also was the first time that I had to remove the crankshaft harmonic balancer and with a 3 jaw puller it came off readily.
Thanks,
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
Tom
1995 850
2004 S60,
2006 S60 2.5T
2012 S60 T5
- Eric66
- Year and Model: 2008 S60 T6
- Has thanked: 3 times
Hi Tom,
I have a 2013 Volvo T5 S60 that is coming up on 100K. I havent been able to locate any MOP's (method of procedure) on it either. So I'm going to get quotes from the local Volvo specialists and if that makes me vomit in my throat, I'll tackle it myself. Last one I did was on an '04 2.5T. Which cam lock tool did you purchase?
Regards,
Eric
Regards,
Eric
astrogence
- Year and Model: 2013 S60 T5
Did you ever get a quote for a timing belt replacement? I need one replaced ASAP but can't find any tutorials on itEric66 wrote: 24 Feb 2020, 19:55 Hi Tom,
Regards,
Eric
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Here is a set of VIDA procedures for the 2012 S60 T5 in pdf
Hope this helps
PS
I've never ever gotten a quote for a timing belt replacement, only heard stealership rumors like an arm+leg+tax
Hope this helps
PS
ACC Belt.pdf- (397.12 KiB) Downloaded 381 times
Eng Pad RH.pdf- (309.98 KiB) Downloaded 306 times
TBelt.pdf- (419.21 KiB) Downloaded 488 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 2009 Views
Last post by paulg22
- 869 Views
Last post by Syoma
- 20 Replies
- 17380 Views
Last post by Hurtfeelings
- 803 Views
Last post by Man4
- 5239 Views
Last post by jimmy57
