Headlight wipers not parking
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
Every once and awhile my driver's side headlight wiper won't park in the correct position, usually about half way up. But next time when I turn the car on it will return to the correct park position. I was going to remove the motors and inspect and lube the geartrain, but I have to move the condenser forward, so I put it off for now. Is there something that usually goes wrong in there that can be fixed that causes this? I'm thinking a switch not making contact all the time.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There is a resistor disc inside the motor to act as an automatic circuit breaker of sorts. The disc will get corrosion or fail. You remove motor and carefully pry tabs and open it to get access. When you get inside you can follow some wires and find the silver disc between two sprung finger contacts. The motor will stop wherever and then when ignition is off the resistor cools and then on next key cycle it either parks or at least goes part way towards park until next off and on cycle.
- 7023 Views
Last post by oragex
- 1026 Views
- 1592 Views
Last post by user17600
- 3152 Views
Last post by erikv11
- 15 Replies
- 7655 Views
Last post by wizechatmgr
