hi looking to drain and change fluid for 2002 volvo s40 automatic 1.9 litre engine
enclosed is a pic where i think might be the transmission drain plug..not sure,,if so bracket is in way so cant use socket,,looks like an ajustable i have to use,,as well read on the net ,,it should be a 24 mm nut correct
thanks
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
where is transmission drain plug for 2002 s40
- Year and Model: 2002 volvo s40
- Has thanked: 0
- Been thanked: 0
- Has thanked: 0
- Been thanked: 0
Re: where is transmission drain plug for 2002 s40
better pic
- RickHaleParker
- Has thanked: 3 times
- Been thanked: 374 times
Drain plug is 24mm.
Don't take it out at first, just loosen it and let the fluid trickle out. This way the fluid does not hit the bracket, fly all over the place and make a big mess.
It might take an hour to drain 4 quarts but compared to cleaning a mess, it is good time management.
Last edited by RickHaleParker on Wed Dec 04, 2019 4:52 pm, edited 1 time in total.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
- Has thanked: 0
- Been thanked: 0
thanks for info..from my enclosed pic,,does that look like the transmission drain plug...im guessing there should be only one 24mm plug around
correct
correct
- alschnertz
- Year and Model: 1995 854T
- Been thanked: 7 times
Yes, that looks like it. I posted a photo of it years ago here, but can't find the post right now.
I usually make a aluminum foil trough and place it under the drain and above the crossmember to avoid a mess. It's worked for me.
Re. another of your comments...I would NOT try to use an adjustable wrench on the drain plug. There's too big a chance of rounding it off.
Use a proper sized box wrench instead. You may want to have a new drain plug washer too as the one in the photo looks like it could use replacement.
Be sure to use Mobil 3309 (or equivalent) fluid only.
Edit: The photo is in this thread: viewtopic.php?f=8&t=77752
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Missing Transmission Drain Plug Magnet?
by a3inverter » Wed Jul 25, 2018 6:19 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 4 Replies
- 380 Views
Last post by a3inverter
Mon Jul 30, 2018 11:56 am
- 237 Views
Last post by dm635
Fri Jan 04, 2019 1:43 pm
P80: Leaky Oil Drain Bolt - Drain Washer/Gasket options?
by theWIFES_S70 » Sat Oct 14, 2017 10:52 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 9 Replies
- 1049 Views
Wed Oct 31, 2018 5:22 am
850 oil drain plug.
by rguzz » Mon Nov 28, 2016 9:31 am » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 4 Replies
- 368 Views
Last post by rspi
Mon Nov 28, 2016 1:55 pm
