Hi guys, looking for some help if someone could shed some light.
I drive a base 2005 xc90 2.5T, with the cloth/leather combo. Drivers side is power, passenger is manual.
I found a set of leather seats off an 08 xc90 and was wondering if it is compatible, plug and play? I know I probably cant make my passenger seat power but wanted to make sure I can just bolt it on and have the drivers seat swap work. The second row I would imagine is compatible.
Thanks all!
Xc90 seat compatibility
Danilosilni
- Year and Model: 2005 XC90 2.5T
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Mechanically speaking, in theory the XC90 platform remained relatively unchanged from '03 to '14, but double check the way the seat rails look with their attachment points, see if they are like in your car. On the S60 platform, some people swapped the passenger manual seat with electric ones and the seat was working. My worries would rather be on the SRS modules fixed under the seat (along with some other sensors perhaps). Not sure about the compatibility as this could also be related to some computer software version which evolved through the years. I would look into a complete module connector swapping which is not going to be fun (Volvo is obsessed with security so these would be quite hard to remove from the seat frame). May want to practice at a car at the junkyard to undo the connectors - these can be quite tricky the way they are being disconnected
Not lastly, these seats weight a ton, two persons needed and the seat might need folded and headrest removed (see Youtube) to pull them out of the car. Really careful moving them around, those rails love grabbing and stabbing the various cables/amp under the seat
eapowers64
- Year and Model: 2004 xc90
- Has thanked: 2 times
I am pretty sure that they are not compatible - the mounting points are different. I have an 04 and was in a pull-a-part junkyard looking for a seat bottom that was better than my tattered one. I think that the vehicle I was scavenging on that day was an 08 and the brackets on the bottom of the seat through which the bolts go were different from the ones on the 04.
Danilosilni
Thanks for all replies. I have decided not to risk it since the seller is not responsive to photos of the mounting and connectors underneath.
- 864 Views
Last post by dyn blin
- 1072 Views
Last post by rspi
- 988 Views
- 1540 Views
Last post by MadeInJapan
- 1535 Views
Last post by lummert
